Author Topic: transparent lisp command  (Read 16158 times)
Marc'Antonio Alessi
  • Marco
Re: transparent lisp command
« Reply #15 on: May 13, 2016, 06:09:24 AM »
Sorry, I am not sure what that a rotated (getcorner) is. Here is what I am looking for:
Start the line command, before selecting your first point, shift+right click and use the command modifier "FROM". Now select the basepoint, now for the offset distance, I do not get a "rubberband" that uses polar tracking. I am "blindly" having to select the offset point angle when using direct distance input.
Contrast this with the end point of the line command. If I use the "from" command modifier on the end point, all of a sudden I get to use the rubberband w/ polar tracking when specifying the offset point.
I am trying to make a custom "from" command modifier that uses the rubberband in all circumstances.
AutoCAD 2013 (sorry for italian prompt):
---------- inside Command -------------
Comando: LINEA
Specificare primo punto: (ALE_From "ACTIVE")
>>Base point <Lastpoint> <508.85,1028.15,0>:
>>Offset: @25,25
Specificare punto successivo o [Annulla]:
---------- nesting inside Command -------------
Comando:  LINEA
>>Base point <Lastpoint> <548.36,1019.7,0>: (ALE_From "ACTIVE")
>>Base point <Lastpoint> <548.36,1019.7,0>: @22,22
>>Offset: @11,11
>>Offset: @33,33
>>Offset: @-55,-55
---------- inside Lisp -------------
Comando:  CIRCLETEST
Circle center <Lastpoint> <462.53,979.22,0>: (ALE_From nil)
>>Base point <Lastpoint> <462.53,979.22,0>:
>>Offset: @20,20
Circle diameter <9.41>:
---------- nesting inside Lisp -------------
Comando: CIRCLETEST
Circle center <Lastpoint> <543.33,1047.13,0>: (ALE_From nil)
>>Base point <Lastpoint> <543.33,1047.13,0>: (ALE_From nil)
>>Offset: @11,11
>>Offset: @22,22
>>Offset: @-33,-33
Circle diameter <9.88>:
; [_Button...]^P$M=$(if,$(getvar,cmdactive),(ALE_From """""""ACTIVE"""""""),(ALE_From nil));
(defun ALE_From (CmdAct / BasPtn Pnt001 CurBlp CurOrt)
    (graphscr)
    (setq CurBlp (getvar "BLIPMODE")  CurOrt (getvar "ORTHOMODE"))
    (setvar "BLIPMODE" 1)   (setvar "ORTHOMODE" 0)
    (setq
      BasPtn   (ALE_GetPoint 40 "" ">>Base point <Lastpoint>" (getvar "LASTPOINT") (getvar "LASTPOINT"))
      Pnt001   (ALE_GetPoint 41 "" ">>Offset"  nil BasPtn)
    (setvar "BLIPMODE" CurBlp) (setvar "ORTHOMODE" CurOrt)
      ( (and Pnt001 CmdAct) (command "_NONE" Pnt001) (princ) )
      ( Pnt001 )
      ( T (alert "Point not found."     ) (princ) )
(defun C:CircleTest (/ Pnt001 EntLas SelSet)
  (setq Pnt001 (ALE_GetPoint 40 "" "Circle center <Lastpoint>" (getvar "LASTPOINT") (getvar "LASTPOINT")))
  (setq #mdist (ALE_GetDist  46 "" "Circle diameter" #mdist Pnt001))
  (command "_.CIRCLE" "_NONE" Pnt001 (/ #mdist 2.0))
  (setvar "LASTPOINT" Pnt001)
(defun ALE_GetDist (IGtBit KwdStr PrmStr DefRea BasPtn / InpVal)
  (if DefRea
    (setq
      PrmStr (strcat "\n" PrmStr " <" (rtos DefRea) ">: ")
      IGtBit (logand IGtBit 254)
    (setq PrmStr (strcat "\n" PrmStr ": "))
  (initget IGtBit KwdStr)
  (setq InpVal (if BasPtn (getdist BasPtn PrmStr) (getdist PrmStr)))
  (if InpVal InpVal DefRea)
Edit: upoint = ALE_GetPoint
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #16 on: May 13, 2016, 07:23:26 AM »
Bringing it back to minimal basics ...
The following code when compiled as a separate namespace VLX loads and runs in the document it is loaded in without error and as expected.
The command will run either :
from TAC at the command line.
from 'tac transparently during an AutoCAD command.
from 'tac transparently during a lisp function.
The VLX is listed from (vl-list-loaded-vlx)
ie -> (test-ACRX-CMD)
Code to compile :
  1. ;;; test-ACRX-CMD.LSP
  2. ;; kdub @ theSwamp 2016.05.13
  3.
  4. ;;; Workaround for (vlax-add-cmd) bug.
  5. ;;; by Stephan Koster
  6.
  7. ;; Comments by JRFlemming: This code should be
  8. ;;; run before adding any other commands with vlr-add-cmd.
  9. ;;; Otherwise, when using added commands in multiple documents
  10. ;;; (MDI mode), sometimes the commands fail with a "Visual LISP
  11. ;;; command document mismatch" error. Apparently vlax-add-cmd
  12. ;;; must be called in a document in order to activate commands
  13. ;;; in that document.
  14. (defun DummyCommand () NIL)
  15. (vlax-add-cmd "DummyCommand" 'DummyCommand)
  16. (defun AddCommandsHelper (a b) (vlax-add-cmd "DummyCommand" 'DummyCommand))
  17. ;; Install dummy command reactor only if it's not
  18. ;; defined already
  19. (or *DummyCommandReactor*
  20.     (setq *DummyCommandReactor*
  21.            (vlr-docmanager-reactor
  22.              NIL
  23.              '((:vlr-documentbecamecurrent . AddCommandsHelper))
  24.            )
  25.     )
  26. )
  27. ;;---------------------------------------------------------
  28.
  29. (defun test:ACRX-CMD () (princ "TEST-COMMAND called"))
  30.
  31. (vlax-add-cmd "tac" 'test:ACRX-CMD "tac" ACRX_CMD_TRANSPARENT)
  32. ;;---------------------------------------------------------
  33.
Code to test:
  1. (defun c:Testtac ( /  p1 p2 )
  2.
  3.   (setq p1 (getpoint "\nSelect a point:"))
  4.   (prompt
  5.     "\nUse 'tac during this command, before selecting the next Point."
  6.   )
  7.   (setq p2 (getpoint p1 "\nSelect another point:"))
  8.
  9.   (princ)
  10. )
  11.
When we load and run the Testtac command we get this, as expected.
Command: TESTTAC
Select a point:
Select another point:'tac
TEST-COMMAND called
Resuming TESTTAC command.
Select another point:(3917.36 2685.2 0.0)
Command:
Now, when we open another document, the TAC command is registered and available at the command line ..
but ;
returns
Command: TAC
; error: Visual LISP command document mismatch: tac
When we load and run the Testtac command we get this.
Command:
TESTTAC
Select a point:
xError: Visual LISP command document mismatch: tac
Backtrace:
:ERROR-BREAK.6 "Visual LISP command document mismatch: tac"
:ARQ-CMD-CALLBACK.3 (nil 2)
Select another point:(2643.28 3509.62 0.0)
Command:
This has been tested in AutoCAD 2016.
From my research  this Visual LISP command document mismatch has been an issue since 1999.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vlax-add-cmd-in-mdi-mode/td-p/889283
And numerous similar queries.
Does anyone have a resolution for this problem ...
It would be nice to get some response from AutoDesk regarding this.
Regards,
Kerry.
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
« Reply #17 on: May 13, 2016, 07:42:23 AM »
For anyone who is more comfortable posting on the AutoDesk Discussion Forum I've started a thread here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/regarding-error-visual-lisp-command-document-mismatch/td-p/6324669
Coltm16
« Reply #18 on: May 13, 2016, 07:49:09 AM »
Kdub, thank you for your time and research. Looks like we will just try again in 17 years and see if anything has changed.
kdub_nz
  • SuperMod
« Reply #19 on: May 13, 2016, 07:57:52 AM »
It's frustrating because I'd thought I had this working about 12 or so years ago ... I used a lot of Separate Namespace apps back then.
It might just be oldtimers syndrome.
PKENEWELL
« Reply #20 on: May 13, 2016, 09:38:47 AM »
Hi Marc'Antonio,
For some reason this method has not been working for me since AutoCAD 2009 I think. ...
I do not quite understand what you mean, have you tried my functions?
I am using in all versions of AutoCAD/Bricscad since it was introduced the bit 128 for initget (maybe 1990).
Try to make the two buttons:
[_Button("« Middle Point", YourIcon, YourIcon)]^P$M=$(if,$(getvar,cmdactive),(ALE_MidPoint """""""ACTIVE"""""""),(ALE_MidPoint nil));
[_Button("« Progressive Distance", YourIcon2, YourIcon2)]^P$M=$(if,$(getvar,cmdactive),(ALE_DistPr """""""ACTIVE"""""""),(ALE_DistPr nil));
and test ALE_MidPoint or ALE_DistPr inside a command or AutoLisp function.
Hi Marc - Yes I tried your functions. What I specifically was attempting was the command line transparent command that you added with (vlax-add-cmd). I still have the same problem as the OP. Your buttons don't use the command line shortcut.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
PKENEWELL
« Reply #21 on: May 13, 2016, 09:45:13 AM »
Hi kdub,
The reactor method by Stephan Kostar back in 1999 solved the problem for me and the commands I defined worked until about Acad 2009 roughly (put them on the back burner and I can't remember for sure when now it stopped working). Looks like I'll have to compile to separate namespace VLX to make them work now. Wanted to avoid that if possible.
EDIT: Oh - I see now you have the same issue even from a separate namespace VLX? Grrrr.
« Last Edit: May 13, 2016, 09:59:17 AM by PKENEWELL »
PKENEWELL
« Reply #22 on: May 13, 2016, 10:14:51 AM »
I can see others have not been able to get a reply to this either:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/visual-lisp-command-document-mismatch-xlax-add-cmd-error-again/m-p/3168248/highlight/true#M299317
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/custom-zoom-window/m-p/2960566/highlight/true#M295500
I have to make my own apologies for the Adesk Forums. I wasn't checking them for a long time (was working on Solidworks for a while), and didn't see these others before. Not that I could've helped - still stumped in this issue myself.  :x
PKENEWELL
« Last Edit: May 13, 2016, 11:06:07 AM by PKENEWELL »
Marc'Antonio Alessi
  • Marco
« Reply #24 on: May 13, 2016, 11:44:34 AM »
Honestly now I can not get my example with "vla-SendCommand", maybe I am way off base... 8-) I'll try again but I'm not very motivated because I saw that in Bricscad there are other problems with (vlax-add-cmd ...).
The OP not ask for command line shortcut but:
"I am trying to make a custom "from" command modifier that uses the rubberband in all circumstances."
Why you can not use a button instead of the command line?
Here is another example that is closer to the OP request (no add-cmd)
(defun ALE_Track (CmdAct / BasPtn Pnt001 CurBlp CurOrt)
    (graphscr)
    (setvar "BLIPMODE" 1)   (setvar "ORTHOMODE" 1)
    (setq
      Pnt001   (ALE_GetPoint -88 "" ">>Distance"  nil BasPtn)
      ( Pnt001 )
Marc'Antonio Alessi
  • Marco
« Reply #25 on: May 13, 2016, 12:19:16 PM »
Here is the command line test:
(defun ALE_TR ( )
  (vla-SendCommand *acDoc* "!(ALE_Track \"ACTIVE\") ")
(vlax-add-cmd "tr" 'ALE_TR  "tr" 1)
Command: L LINE
Specify first point: 'tr
Resuming LINE command.
Specify first point: !(ALE_Track "ACTIVE")
>>Base point <Lastpoint> <139.32,394.28,0>:
>>Offset:
Specify next point or [Undo]:
Marc'Antonio Alessi
  • Marco
« Reply #26 on: May 13, 2016, 01:13:09 PM »
In Bricscad we need a "\n" inside "(ALE_Track \"ACTIVE\")\n" instead of space, works in AutoCAD also.
Inside Lisp we do not need "!" before:
(defun ALE_TL ( )
  (vla-SendCommand *acDoc* "(ALE_Track \"ACTIVE\")\n")
(vlax-add-cmd "tl" 'ALE_TL  "tl" 1)
Comando: CIRCLETEST
Circle center <Lastpoint> <191.56,101.55,0>: 'tl
Ripresa del comando CIRCLETEST.
Circle center <Lastpoint> <191.56,101.55,0>: (ALE_Track "ACTIVE")
>>Base point <Lastpoint> <191.56,101.55,0>:
>>Offset:
Circle diameter <31.6>:
kdub_nz
  • SuperMod
« Reply #27 on: May 13, 2016, 01:27:17 PM »
(defun ALE_TR ( )
Command: L LINE
>>Offset:
Marc'Antonio
Are you saying you can get that to work in multiple documents from the command line ??
Which version of  ALE_Track are you using in AutoCAD ?
Regards,
PKENEWELL
« Reply #28 on: May 13, 2016, 01:32:04 PM »
Have you tried opening a 2nd drawing in the same session and testing if the command still works? That's the problem is it doesn't work if you open a 2nd drawing in the same session.
If the OP just wanted a button I don't think it would be an issue. I was under the impression that he also wanted a transparent command that you can use with ( ' ) in front of it. The whole point of my replies is that there used to be a working method for this - but it doesn't work anymore. (vlax-add-cmd) does not want to function in MDI mode.
Marc'Antonio Alessi
  • Marco
« Reply #29 on: May 13, 2016, 06:07:41 PM »
Marc'Antonio
#1: Yes but with this version:
(defun ALE_TR ( / obj)
  (setq obj (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vla-SendCommand obj "!(ALE_Track \"ACTIVE\")\n")
  (vlax-release-object obj)
#2: this (prompt "Distance" was "Offset" but the function is the same):
    (graphscr)
    (setq
      ( Pnt001 )
