Author Topic: Modify Dimension style  (Read 1377 times)
Coder
« on: May 08, 2016, 06:53:41 AM »
Hello guys.
I am trying to modify a dimension style like below:
1- Suppress Dimension lines ( Dim line 1 and Dim line 2).
2- Text Placement vertical to ( Below ).
If I call the system variable, a new override dimension style would be created and this is what I don't want.
I tried to dump the DimStyle but it seems that it does not have functions to allow me to modify the style.
Thanks in advance.
roy_043
  • BricsCAD 18
Re: Modify Dimension style
« Reply #1 on: May 08, 2016, 03:58:17 PM »
You can either use entmod or the CopyFrom method.
Coder
« Reply #2 on: May 09, 2016, 12:17:36 AM »
Thank you roy for your reply.
Can you please give an example ?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: May 09, 2016, 02:03:45 AM »
Start Here :
Called Kerry in my other life
I live at UTC + 13.00
roy_043
  • BricsCAD 18
« Reply #4 on: May 09, 2016, 04:34:40 AM »
... Or read the docs.
Coder
« Reply #5 on: May 09, 2016, 08:09:59 AM »
I already have a good information about the function CopyFrom thanks.
But I would like to know how to use dxf with entmod, if you can give an example I would be very thankful.
roy_043
  • BricsCAD 18
« Reply #6 on: May 09, 2016, 09:25:06 AM »
https://www.theswamp.org/index.php?topic=41211.msg463666#msg463666
Coder
« Reply #7 on: May 09, 2016, 09:40:16 AM »
Thank you roy, and Kerry for your kind replies and patience.
