Author Topic: Font traffic  (Read 3798 times)
Font traffic
« on: May 04, 2016, 11:55:08 AM »
I'm considering the move to true type fonts for our standards.
ChrisCarlson
Re: Font traffic
« Reply #1 on: May 04, 2016, 12:08:33 PM »
We are currently working on the transition. TT is much cleaner and more widely accepted for PDF viewers. AutoCAD's implementation of SHX text search was atrocious.
Dinosaur
Re: Font traffic
« Reply #2 on: May 04, 2016, 12:14:50 PM »
My only real preference was that it NOT be txt.shx but I do like the shx better if only because I could control width factor with greater precision and boldness with pen weight.  I also found the attachment point for TT fonts to be a bit dodgy when lower case and certain punctuation were involved.
dgorsman
Re: Font traffic
« Reply #3 on: May 04, 2016, 01:07:10 PM »
TTF with the usual caveats e.g. not using AutoCAD as a substitute for Word, not using some oddball font.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
alanjt
  • Standby for witty remark...
Re: Font traffic
« Reply #4 on: May 04, 2016, 01:30:55 PM »
Funny, that's one of the biggest reasons I like ttf.
Dropbox
Matt__W
  • I like my water diluted.
Re: Font traffic
« Reply #5 on: May 04, 2016, 01:36:39 PM »
TTF text is searchable in PDFs while SHX text is not.
Autodesk Expert Elite
Rob...
Re: Font traffic
« Reply #6 on: May 04, 2016, 01:39:15 PM »
... without some sort of conversion. I think BlueBeam does it and the latest DWG to PDF driver does it, too, I think.
CAD Tech
ChrisCarlson
Re: Font traffic
« Reply #7 on: May 04, 2016, 01:53:08 PM »
DWG to PDF simply makes a pdf "comment" of the text entity, which is then searchable. The actual PDF is not searchable.
Jeff H
Re: Font traffic
« Reply #8 on: May 04, 2016, 03:24:25 PM »
We use both and custom ones because we are total f**k*** morons, but seems like .shx are better for attributes especially blocks inserted with z != 0
danallen
Re: Font traffic
« Reply #9 on: May 04, 2016, 05:18:24 PM »
TTF because I want our drawings to match our memo & letters, also using bluebeam to markup can have matching consistent appearance. Have had no issues with performance.
rkmcswain
Re: Font traffic
« Reply #10 on: May 05, 2016, 09:47:56 AM »
Quote from: DinØsaur
.... I do like the shx better .... because I could control width factor with greater precision and boldness with pen weight.
Exactly.
I can have one style, with one font, and have an almost infinite choice of combinations of text height and thickness (pen width), whereas TTF pen widths are limited. You want text Arial text 2" high with a pen width of 0.005"? Forget it. You want Calibri 0.08" high and a pen width of 0.028"? Forget it.
With TTF, you end up having one style for regular text, one for BOLD text and one for Narrow text and even more if there are other variations of the font available.
jonesy
  • SuperMod
Re: Font traffic
« Reply #11 on: May 05, 2016, 09:58:45 AM »
Company standards are True Type, so I use True Type :)
Re: Font traffic
« Reply #12 on: May 05, 2016, 10:02:13 AM »
I just generally hate all text in drawings.
Re: Font traffic
« Reply #13 on: May 05, 2016, 10:16:34 AM »
That makes sense - you seem to hate much of the text you've read anywhere.
Re: Font traffic
« Reply #14 on: May 05, 2016, 10:26:34 AM »
I think you have me all wrong....
I don't hate all text that I've read...I do not like reading wrong information, or anything from those that are misinformed, or hold their opinions so dearly that they will not tolerate them being questioned or scrutinized for validity.
