Hello guys.
I am having a hard time to find if there is a coordinate point between the two points placed on a polyline and I have attached an image showing the problem in more details.
How can I get the coordinate point of a Polyline that is placed between the two points ( p1 p2 ) otherwise return nil if not found.
I hope also if the codes can find if there are more than one coordinate in some situations.
(setq poly (car (entsel "\nSelect polyline :")))
(setq p1 (vlax-curve-getpointatdist poly 0.5))
(setq p2 (vlax-curve-getpointatdist poly 1.5))
Thanks in advance.
