Author Topic: Civil 3D | Dynamic Scale Bar  (Read 8930 times)
BlackBox
« on: April 28, 2016, 02:10:12 PM »
I've been using a dynamic North Arrow for some time, and finally setup a Scale Bar to link to my Viewports.
It's working fine for the most part, and I've cleaned up the hard-coded drawing(s), so my North Arrow, and Scale Bar show within the Ribbon UI.
The only issue I'm really having, and cannot see a way to fix, is that when the Scale Bar changes with a Viewport scale change, it always adds a fractional change in the ten-thousandths+ that prevents it from reading to the foot (US Imperial here). :-o
How the heck do I get it (the attributes?) to STOP reading past ##.0, or round down to integer feet?
TIA
Re: Civil 3D | Dynamic Scale Bar
« Reply #1 on: April 28, 2016, 02:41:14 PM »
I would think that formatting the field to round to whole number would resolve that...
BlackBox
« Reply #2 on: April 28, 2016, 03:29:38 PM »
What Field? :?
Civil 3D dynamic Scale Bar is 'Map.ScaleBar.Div.Length' parameter-based, and the vanilla Attributes are simply Tagged as 'Map.Scale.Bar.Div.*' - as I understand it, Map functionality is actually what populates the values accordingly.
Changing drawing precision is not an acceptable solution, as has been suggested in Autodesk forums; hence my question here.
Cheers
« Reply #3 on: April 28, 2016, 03:35:43 PM »
What Field? :?
Cheers
OH...sorry I thought you had created your own dynamic block for that purpose.  hmmm
« Reply #4 on: April 28, 2016, 03:37:01 PM »
perhaps replace those default attributes with fields that ARE properly formatted
  • Custom Title
« Reply #5 on: April 28, 2016, 03:41:24 PM »
For the record; i hate those things! :)
I still use a simple old block with attributes. It works!
carry on ...
BlackBox
« Reply #6 on: April 28, 2016, 04:13:36 PM »
Thanks, Guys!
The North Arrow has been awesome for the past couple of years, so I finally put the time in to setup the Scale Bar, replace those listed in the OOTB UI, etc., and it's just bonkers.
Unless someone knows how to fix this undesired behavior, I'm going back to using the vanilla Block. *kicks dirt*
rkmcswain
« Reply #7 on: April 28, 2016, 05:49:20 PM »
Ha... Never found a reason to stop using what works. :-)
BlackBox
« Reply #8 on: April 28, 2016, 06:47:18 PM »
I know one can use a Field to reference the Viewport's Standard Scale (I do that within the Title Block now), and I don't mind another reference dependency, but is there a way to populate a Scale Bar's ' 0 - <ScaleAsInteger> (at 1") - <ScaleAsInteger X 2> (at 2") ' format?
Cheers
nobody
  • .net stuff
« Reply #9 on: April 28, 2016, 09:46:05 PM »
A field?  Additional Format -> Conversion  Factor?
Cheers
huiz
  • Certified Prof C3D
« Reply #10 on: April 29, 2016, 04:09:18 AM »
You can use a formula.
Included a block with a few attributes and a formula to the block scale.
Maybe you can use the same formula with the current viewport scale, but then you need to place the block in Modelspace.
Ow btw, texts inside the blocks are in Dutch but you probably understand the meaning :-)
BlackBox
« Reply #11 on: April 29, 2016, 09:25:21 AM »
Thanks, Henrique!
The formula does work, but requires the block be inserted in Model space, unfortunately. :-(
In Civil 3D, the scale bar (and north arrow) are 'linked' to a Viewport, from which they extract the necessary scale (or direction) information. I can do similar with a Field, however referencing the Viewport object only yields the Standard Scale as string, such as "1\" = 40'". :-(
Using a Field that references a Formula, which itself references a Field using [0.5\1.0\2.0] / <CANNOSCALEVALUE> works perfect... But again, requires the Scale Bar be in Model space (Paper space == 1:1), which now means also accounting for the 'dynamic' scaling of the Scale Bar block itself, unless I want to introduce another manual task. Model space can also have a different Annotation Scale, than the Paper space Viewport, which could present an issue (I purposefully make them the same, but they're not 'linked'). :|
... Grumble, mumble, grrr... Need some coffee. :-D
sljohnson
« Reply #12 on: April 29, 2016, 02:35:57 PM »
Thinking this over lunch, here is an outline of what came to mind, I don't know if the User Parameter is the right tool for this:
Define a scale block with User Parameter ScaleBarCustom (Default =1) and attributes for ScaleBar.Div0, ScaleBar.Div1, ScaleBar.Div2, ...
Then use deisel expressions that references the ScaleBarCustom Parameter that calculates ScaleBar.Div* accurately. Keep in mind that the "Custom Scale" Object Property with no formatting is the field that will be entered into ScaleBarCustom. e.g. (1/ScaleBarCustom)*2
Now to use that block, a lisp to insert the block that gets the "Custom Scale" field (not the value, the actual linked field) from the selected viewport and  then inserts the block while writing the 'Custom Scale" field for the selected viewport. Or it could re-associate a "Custom Scale" field already in the block with the selected viewport. I'm not sure which would be easier to implement.
I don't know if the above is even possible or the "proper" way to do it, however thus ends my lunch time brainstorm...or light drizzle.
Best,
Shannon
Jeff H
« Reply #13 on: April 29, 2016, 03:35:59 PM »
Here is what I use but never really use the second bar scale since only needed for 3/32" but other works great for all others used.
alanjt
  • Standby for witty remark...
« Reply #14 on: April 29, 2016, 03:45:51 PM »
Are you connecting the dynamic north arrow to the viewport with code, or is there a way to do it without?
Dropbox
