Author Topic: Conversion Factor: Metric to Imperial  (Read 3836 times)
GPeyton
« on: April 28, 2016, 08:33:27 AM »
When you download a nice Dynamic Block from the internet and it is in Metric units and you work in Imperial units. Is there a Conversion Factor that can change it into Imperial units without losing any of the Dynamics of the block? Hopefully this is not a stupid question. Thanks in advance.
Rob...
Re: Conversion Factor: Metric to Imperial
« Reply #1 on: April 28, 2016, 08:35:16 AM »
There are several. You need to determine what units to what units, i.e. mm to inches is 25.4.
CAD Tech
ChrisCarlson
« Reply #2 on: April 28, 2016, 08:55:34 AM »
To go from mm to inches it's 0.0393701.
Rob...
« Reply #3 on: April 28, 2016, 08:58:11 AM »
That would be correct, sorry. I'm working on a site plan and my inverts are upside down, too.
CAD Tech
« Reply #4 on: April 28, 2016, 08:59:26 AM »
cm to inches  0.393701
dm to inches  3.93701
Rob...
« Reply #5 on: April 28, 2016, 09:02:05 AM »
M to feet - 3.280839895013123
CAD Tech
Dinosaur
« Reply #6 on: April 28, 2016, 09:50:27 AM »
Well there are feet and then there are other feet ... imperial feet will give you a surprise if you are converting to US SURVEY feet for state plane conversion.  Sorry but I do not remember the true conversion factor, only the wrath of the surveyor if difference was neglected.
Rob...
« Reply #7 on: April 28, 2016, 09:53:33 AM »
Oh yeah, sure, confuse things even further.
http://vterrain.org/Projections/sp_feet.html
CAD Tech
« Reply #8 on: April 28, 2016, 10:01:35 AM »
International Foot (also commonly called the foot) and the U.S. Survey Foot. The International Foot (which we were all taught in school) is defined as 0.3048 meters, whereas the U.S. Survey Foot is defined as 0.3048006096 meters. The difference of the two equates to 2 parts per million.
« Reply #9 on: April 28, 2016, 10:07:22 AM »
« Reply #10 on: April 28, 2016, 10:17:16 AM »
Dinosaur
« Reply #11 on: April 28, 2016, 11:10:25 AM »
Oh, I know it had less real significance than a mosquito phart during a hurricane but not to the folk reviewing our state plane ties ... if the wrong conversion was used or even noted in the statement on the plat incorrectly, the whole approval was stopped until EVERYTHING was examined and the universe was put back in order.
My apologies to the original poster for the thread hijack but has been awhile since I felt I could roil TheSwamp waters a little and could not resist the temptation.
« Reply #12 on: April 28, 2016, 11:38:07 AM »
Go ahead...feel free
Others do so without any provocation, nor to even add insight or wisdom
Jeff H
« Reply #13 on: April 28, 2016, 12:15:19 PM »
Does the -DWGUNITS update blocks?
« Reply #14 on: April 28, 2016, 12:21:27 PM »
I don't think so
