Author Topic: How do you access your favorite commands?  (Read 3059 times)
MSTG007
« on: April 25, 2016, 07:21:41 AM »
Just getting some more user input here. I was curious how people access there favorite commands. Tool Palettes, Ribbon, command line (keyshort cuts), or mouse menus?
I am currently using the tool palette, now creating a new tab called favorites and moving them over.
Thanks for the input!
Civil3D 2020
tedg
Re: How do you access your favorite commands?
« Reply #1 on: April 25, 2016, 08:01:01 AM »
I assume you're talking about OOTB commands..
For me, I mostly use the command line.
For the ones I use the most: alias' to the actual commands within my acad.pgp file.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
ChrisCarlson
« Reply #2 on: April 25, 2016, 08:02:28 AM »
Simple commands and lisp routines? Aliases
Macro's? Custom ribbon panel
Palletes are lame and toolbars are being phased out.
Rob...
« Reply #3 on: April 25, 2016, 08:18:37 AM »
Right click shortcut menu, right click contextual menu (time sensitivity turned on), contextual ribbon.
CAD Tech
rkmcswain
« Reply #4 on: April 25, 2016, 09:17:02 AM »
Straight up command access?
80% = command line
10% = toolbars
5% = ribbon
5% = tool palette
Accessing contextual commands in C3D raises the ribbon % somewhat.
rkmcswain
« Reply #5 on: April 25, 2016, 09:17:57 AM »
Quote from: ChrisCarlson
.... toolbars are being phased out.
Hopefully using the same timeline as the screen menu... i.e. 15+ years ... lol
« Reply #6 on: April 25, 2016, 09:42:18 AM »
telepathy
or
Rt-Click
« Reply #7 on: April 25, 2016, 09:47:14 AM »
<alt> <f4>
dgorsman
« Reply #8 on: April 25, 2016, 10:18:22 AM »
Right-click context menu a lot, considering the amount of times I use the previous command list.  Command line for a few simple things, Ribbon for more complex tools ("time lost" moving the pointer is miniscule compared to the time spent thinking) unless they're close to the top of the previous command list.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
NOT SURE
« Reply #9 on: April 25, 2016, 10:36:59 AM »
Aliasedit, or acad.pgp in conjunction with the command line has been the way I've accessed my most frequently used commands for many years.
« Reply #10 on: April 25, 2016, 10:37:46 AM »
80% = command line
10% = toolbars
5% = ribbon
5% = tool palette
Same here.
« Reply #11 on: April 25, 2016, 10:58:51 AM »
Not Tool Palettes or Ribbon.
RONR
  • Mosquito
« Reply #12 on: May 02, 2016, 09:23:03 PM »
Digitizing tablet and command overlay.  All common commands there for 1 pick.
MSTG007
« Reply #13 on: May 03, 2016, 07:19:52 AM »
My favorite command, when they make it, will be to think the command and boom! done! lol. Right now, I'm digging the one key for a command...
Civil3D 2020
NOT SURE
« Reply #14 on: May 03, 2016, 09:00:38 AM »
https://www.researchgate.net/publication/260043587_Human_factors_study_on_usage_of_BCI_headset_for_3D_CAD_modeling
