Trying to import GPS data (lat/Long) into the attached dwg. Latitude for the imported points imports correctly, longitude, not (correct long = ~114 degrees, importing at ~246 degrees). I tried importing from a text file and the csv; same results. Also, the point description did not import. Any idea what I am doing wrong?
Fortunately there were not many points and I was able to manually correct the longitudes to get it out the door. The incorrect points are those numbered 13398 - 13416.
Many thanks in advance - JR
