Author Topic: Node size  (Read 2694 times)
VerticalMojo
Node size
« on: May 11, 2005, 11:55:10 AM »
I cant believe I forgot this variable.......
VerticalMojo
Node size
« Reply #1 on: May 11, 2005, 12:07:12 PM »
PDMODE
now how do I make the nodes circular?
Node size
« Reply #2 on: May 11, 2005, 12:10:00 PM »
Massage with hot oil.
But seriously, try playing with ddptype.
Node size
« Reply #3 on: May 11, 2005, 12:10:21 PM »
(setvar 'pdmode 33) ?
VerticalMojo
Node size
« Reply #4 on: May 11, 2005, 12:11:04 PM »
Heres a Macro I found....
^C^Cpdmode;35;pdsize;3;divide
Node size
« Reply #5 on: May 11, 2005, 12:22:05 PM »
No matter what pdmode setting you have, this will ensure it only draws circles:
(defun RoundNodes ( )
    (setvar "pdmode"
        (logand (~ 64)
            (logior 32
                (getvar "pdmode")
That is, if you had for example a setting of 66, a crosshair and a square, it would be changed to a crosshair and a circle (34).
SPDCad
Node size
« Reply #6 on: May 11, 2005, 01:14:39 PM »
'PSSize' controls the size of the node, with negative numbers being a % ov display area.
PDMode controls the node style.
33 is a circle with a dot in the centre
34 is just a circle
35 is a circle with 'X' crosshairs
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Node size
« Reply #7 on: May 11, 2005, 01:17:41 PM »
Quote from: SPDCad
34 is just a circle
Might wish to revisit those values.
Crank
Node size
« Reply #8 on: May 11, 2005, 01:32:35 PM »
Don't know if it's also a LT-command, but you can try _ddptype .
