Author Topic: LM:ssget  (Read 2973 times)
amc.dicsac
  • Autocad 2008
LM:ssget
« on: April 13, 2016, 05:27:48 PM »
Hello such, someone who can explain to me how I can make a (ssget "_: L") but with the LM func: Mac Lee SSGET
Thank you
;; Un contenedor para la función ssget para permitir el uso de un mensaje de selección personalizada
;; argumentos:
;; msg - mensaje de selección
;; params - lista de argumentos ssget
   (defun LM:ssget ( msg params / sel )
       (prompt msg)
       (setvar 'nomutt 1)
       (setq sel (vl-catch-all-apply 'ssget params))
       (setvar 'nomutt 0)
       (if (not (vl-catch-all-error-p sel))
           sel
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
Re: LM:ssget
« Reply #1 on: April 13, 2016, 06:13:02 PM »
Example:
  1. ;; ssget  -  Lee Mac
  2. ;; A wrapper for the ssget function to permit the use of a custom selection prompt
  3. ;; msg - [str] selection prompt
  4. ;; arg - [lst] list of ssget arguments
  5.
  6. (defun LM:ssget ( msg arg / sel )
  7.     (princ msg)
  8.     (setvar 'nomutt 1)
  9.     (setq sel (vl-catch-all-apply 'ssget arg))
  10.     (setvar 'nomutt 0)
  11.     (if (not (vl-catch-all-error-p sel)) sel)
  12. )
  1. (LM:ssget "\nSelect objects on unlocked layers: " '("_:L"))
amc.dicsac
  • Autocad 2008
Re: LM:ssget
« Reply #2 on: April 13, 2016, 06:31:30 PM »
and if you want to add (ssget "_: L" (list (cons 0 "insert")))
ChrisCarlson
Re: LM:ssget
« Reply #3 on: April 14, 2016, 07:51:43 AM »
It's incredibly annoying that you keep blatantly removing the credits to routines you use. So quit it.
Lee, curious to what instance this wrapper would be better suited than select-if?
« Last Edit: April 14, 2016, 07:56:45 AM by ChrisCarlson »
Re: LM:ssget
« Reply #4 on: April 14, 2016, 08:48:59 AM »
select-if uses entsel/nentsel and therefore only permits a single selection, the above function enables full ssget functionality whilst allowing a custom selection prompt.
MPD
  • Mosquito
Re: LM:ssget
« Reply #5 on: January 24, 2024, 04:53:52 AM »
what if i want
(LM:ssget "\nSelect Pline to Update: " '("_:S") '((0 . "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE")))
Re: LM:ssget
« Reply #6 on: January 24, 2024, 07:34:44 AM »
what if i want
Use -
  1. (LM:ssget "\nSelect Pline to Update: " '("_:S" ((0 . "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE"))))
saunambon654
  • Mosquito
Re: LM:ssget
« Reply #7 on: February 20, 2024, 08:17:13 PM »
Can I use it with (initget function, be like this:
(initget "First Second")
(setq ss (LM:ssget "\nSelect Pline to Update [First/Second]: " '(((0 . "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE")))))
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: LM:ssget
« Reply #8 on: February 20, 2024, 09:49:11 PM »
@ saunambon654
Have you tried  ( tested ) that option. ??
Called Kerry in my other life
I live at UTC + 13.00
saunambon654
  • Mosquito
Re: LM:ssget
« Reply #9 on: February 21, 2024, 01:45:55 AM »
Yes, I hvae tried it.
When I entered "F", it became changing to "Fence" of ssget function.
When I entered "S", it was no change and continued to select object.
So I wonder is there any right way to use with (initget function.
Re: LM:ssget
« Reply #10 on: February 21, 2024, 05:42:17 AM »
No - you cannot use initget with ssget.
BIGAL
  • 40 + years of using Autocad
Re: LM:ssget
« Reply #11 on: February 21, 2024, 10:56:15 PM »
You can build a what filter to use it makes the string that is used in the ssget a 2 step process. This uses a program I have to make choices.
(princ str)
 "Line,Arc"
(setq ss (ssget '((cons 0 str))))
saunambon654
  • Mosquito
Re: LM:ssget
« Reply #12 on: February 23, 2024, 10:30:55 PM »
Thank you Lee! Is there any way to do that without (initget function? Could you please make the sample?
Re: LM:ssget
« Reply #13 on: February 26, 2024, 06:02:26 AM »
Not without writing your own version of ssget.
