Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Get layout name while in its BlockTableRecord object
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Get layout name while in its BlockTableRecord object (Read 1380 times)
Coder
Swamp Rat
on:
April 13, 2016, 03:34:20 AM »
Hello,
I am trying to print all object names in Model space and layouts (object name + layer + layout name) to command line but I am facing a problem with the layout name.
Can anyone tell me how to get the layout name while I am in its space ?.
Thanks in advance.
Code - C#:
[Select]
using
Transaction tr
db
TransactionManager
StartTransaction
BlockTable blks
BlockTable
tr
GetObject
db
BlockTableId
, OpenMode
ForRead
foreach
var
item
in
blks
BlockTableRecord rec
BlockTableRecord
tr
GetObject
item, OpenMode
ForRead
if
rec
IsLayout
Layout lay
Layout
tr
GetObject
rec
ObjectId
, OpenMode
ForRead
foreach
var
obj
in
rec
ent
Entity
tr
GetObject
obj, OpenMode
ForRead
ed
WriteMessage
\n
ent
GetType
Name
") Layer: ("
ent
Layer
") Space: ("
lay
LayoutName
ed
WriteMessage
\n
Logged
gile
Gator
Marseille, France
WWW
Re: Get layout name while in its BlockTableRecord object
Reply #1 on:
April 13, 2016, 03:54:04 AM »
Juste replace:
Code - C#:
[Select]
Layout lay
Layout
tr
GetObject
rec
ObjectId
, OpenMode
ForRead
with:
Code - C#:
[Select]
Layout lay
Layout
tr
GetObject
rec
LayoutId
, OpenMode
ForRead
Logged
Coder
Swamp Rat
Reply #2 on:
April 13, 2016, 04:13:10 AM »
Thank you gile , that works great.
After running the program successfully the program printed (viewport) two times and I am sure I have only one viewport in each layout, What is wrong with that?
Logged
gile
Gator
Marseille, France
WWW
Reply #3 on:
April 13, 2016, 05:38:56 AM »
Nothing wrong, each layout has its own viewport which Number property = 1 (CVPORT sysvar).
Logged
Coder
Swamp Rat
Reply #4 on:
April 13, 2016, 06:47:47 AM »
Many thanks gile for your help.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
