In trying to set up our templates, I have found a need to create a Slopes display to meet the needs of a client requirement. The issue I am running into, is that there are Surface Styles and Surface Properties that contribute to this display.
In the Style, I can define only slopes to be displayed and under the Analysis tab are some Slopes settings, but of these, only the Legend Style seems useful.
To actually control which bands are displayed and the values to use, I have to use Surface Properties. But until a surface is added to a file, there are no surface properties to assign. This makes it very difficult to setup a template if you cannot set these as a default.
Does anyone know if I am missing something here?
Also, is there any way to export the sum of the areas indicated in the Slopes data?
