I've setup two Pipe Styles for Water Mains - Water Main, and Water Main Restrained.
The former just shows centerline, and outer walls (no plot layer) in plan, and the inner walls in profile.
The latter shows centerline, outer walls (no plot layer), and hatch (same no plot layer) in plan, and the inner walls, and hatch (both on "0" layer) in profile.
Problem is, when I XREF the drawing with the Pipe Network, the hatch in plan actually plots, despite being assigned to the same no plot layer as the outer walls. The outer walls do not plot, and the assigned layer is set to no plot in the current drawing.
The Pipe Style allows for different assignments in Plan, and Profile... What am I missing?
