Can pressure pipe labels be changed so they show the distance from center of structure to center of structure, rather than from edge to edge?
not with any level of ease...
Suck :/ Can you confirm...if I create an alignment along a pipe for 3000-ft that has bends / fittings...and the last fitting is station 3000, when I add up the pipe lengths they will definitely not add up to 3000-ft?
Curious how people are addressing the issue with quantities... or if they've run into it? It would definitely get flagged in the states I've worked on as a problem. Historically, in my area, quantities and lengths were to center of structures / bends...not to the edges of them.
