Author Topic: system command such as ".erase" do not use acedSSGet()?  (Read 2544 times)
xinxirong
  • Mosquito
« on: March 09, 2016, 07:48:18 PM »
I want to set a keyword to ssget like this:
acedSSGet(_T("_:K"), promptPtrs,kwordlist,NULL,ssName)
for lisp function (ssget) ,I hook the  acedSSGet and set the keyword "_:K",but i find the "erase" command do not use acedSSGet,which function will use ?
Now I have research out:the "erase" command will pause in beginSSGet,but not in acedSSGet.
the Lisp function (ssget) will first  call acedSSGet ,then call beginSSGet
the question is how can i modify the const TCHAR *pSSControls?
void
   rongge_acedSSGet::beginSSGet(const TCHAR*  pPrompt,
   int  initGetFlags,
   const TCHAR* pKeywords,
   const TCHAR* pSSControls, // str in ADS
   const AcArray<AcGePoint3d>& points,
   const resbuf* entMask)
« Last Edit: March 11, 2016, 04:33:37 AM by xinxirong »
owenwengerd
Re: system command such as ".erase" do not use acedSSGet()?
« Reply #1 on: March 11, 2016, 08:10:25 AM »
Maybe you would have better luck hooking the AcDbHostApplicationServices::displayString() function.
Nakoyasen
  • Mosquito
« Reply #2 on: February 16, 2020, 10:55:43 PM »
Your knowledge allows me to move on, no matter how much trouble.
