Author Topic: concatenate PDF's  (Read 7277 times)
ttechnik
concatenate PDF's
« on: March 04, 2016, 03:22:17 AM »
I would like one pdf file, with some laps.
(vla-put-ConfigName activelayout "DWG To PDF_A3L.pc3")
in repeat cicle:
(vla-PlotToFile acadPlot (strcat filedir text_fix "-" (car (nth i Rajzok))))
I would like not to create separate files
Does anyone have any idea?
Tamás Csepcsényi
David Bethel
Re: concatenate PDF's
« Reply #1 on: March 04, 2016, 06:13:30 AM »
I don't know if it can be done in AutoCAD.
What I do is plot to Postscript files, and have Distiller combine them into a single PDF
It can be automated so that it is a 2 step process
Also ( on my systems at least ) postscript plotting can bypass all prompts and dialog boxes.
-David
R12 Dos - A2K
ttechnik
« Reply #2 on: March 04, 2016, 11:24:20 AM »
Tamás Csepcsényi
Cathy
« Reply #3 on: March 04, 2016, 04:32:07 PM »
Publish allows you the option of a multi-sheet file or single sheet files.  I'm not sure that's an answer to your question though.
MickD
« Reply #4 on: March 04, 2016, 06:29:48 PM »
PDF Creator allows you to save each print in a list that can be combined into one file, have been using it for years and works well.
It can also be automated with vba etc.
Might be worth a look.
- John Carmack
- J.R.R. Tolkien
ttechnik
« Reply #5 on: March 05, 2016, 01:29:49 PM »
Cathy, the publish is not good. I have one layout and print in program after zoom target.
MickD, from lisp send print to PDF creator?
I do'nt want VB programaing
Tamás Csepcsényi
« Reply #6 on: March 05, 2016, 03:12:13 PM »
Use Ghostscript, or something like it, and call it from Autolisp.
gs -dBATCH -dNOPAUSE -q -sDEVICE=pdfwrite -sOutputFile=merged.pdf file1.pdf file2.pdf
ttechnik
« Reply #7 on: March 06, 2016, 06:00:32 AM »
THX.
I install the gs9.18.
But I recive: not recognized command.
Tamás Csepcsényi
Grrr1337
« Reply #8 on: March 06, 2016, 07:41:25 AM »
I agree with Cathy, try with PUBLISH.
The only question is can it be automated with lisp? I don't know anyone ever tried that.
EDIT: I did my research and found BlackBox's publish reactor (I added some stuff and info to it):
;Reactor for PUBLISHING (author: BlackBox)
;Reactor starts upon "AUTOMATICPUB" variable is set to 1, and Ctrl+S (quicksave) the drawing
;NOTE: to PUBLISH IN .PDF format go to "Options" -> "Plot and Publish" -> "Automatic Publish Settings", in General DWF/PDF options change "File format" to PDF
    (setq PBCOLLATE (getvar 'PUBLISHCOLLATE))
    (setvar "PUBLISHCOLLATE" 1)
    (setq PBHATCH (getvar 'PUBLISHHATCH))
    (setvar "PUBLISHHATCH" 1)
    (setq PBALLSHEETS (getvar 'PUBLISHALLSHEETS))
    (setvar "PUBLISHALLSHEETS" 1)
    (setq FIELD-EVAL (getvar 'FIELDEVAL))
    (setvar "FIELDEVAL" 4)
    (setq AUTOPUB (getvar 'AUTOMATICPUB))
    (setvar "AUTOMATICPUB" 1)
    (setq AUTODWFPUB (getvar 'AUTODWFPUBLISH))
    (setvar "AUTODWFPUBLISH" 0)
;AUTOMATICPUB 0 and ctrl+s
;AUTOMATICPUB 1 and ctrl+s to start the reactor
(defun Autopublish:StartReactor ()
  (or *AutopublishReactor*
      (setq preferences (vla-get-Preferences (vlax-get-acad-object)))
      (setq *AutopublishReactor*
     (vlr-docmanager-reactor
       nil
(:vlr-documentbecamecurrent . Autopublish:DocumentBecameCurrent)
(defun Autopublish:DocumentBecameCurrent (rea doc)
  (if (and *AutopublishReactor* (= 1 (getvar 'automaticpub)))
    (prompt (strcat "\n[BlackBox] : AUTOMATICPUB = "
    (itoa (setvar 'automaticpub 0))
(Autopublish:StartReactor)
And maybe this would be handy addition:
;Toggle the AUTOMATICPUB variable:
(defun c:tgAutoPub (/)
  (if (= (getvar "AUTOMATICPUB") 1)
  (setvar "AUTOMATICPUB" 0)
  (princ (strcat "\nAUTOMATICPUB variable is set to \"" (rtos(getvar "AUTOMATICPUB")) "\" "  ))
« Last Edit: March 06, 2016, 08:49:37 AM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
« Reply #9 on: March 06, 2016, 02:53:01 PM »
THX.
That's because Ghostscript needs to be in the "environmental path" for Windows before you can use just "gs ...". Otherwise, you will have to use a fully qualified path like: "c:/Ghostscript/bin/gs.exe ..."
ttechnik
« Reply #10 on: March 06, 2016, 04:53:18 PM »
Yes, John.
I use fully path.
But I have gswin64.exe  and gswin64c, not gs.exe.
Not recognized command....
Tamás Csepcsényi
roy_043
  • BricsCAD 18
« Reply #11 on: March 07, 2016, 03:04:08 AM »
The executable is named gswin64c.exe instead of gs.exe in your case.
The command line to invoke Ghostscript is essentially the same on all systems, although the name of the executable program itself may differ among systems.
« Reply #12 on: March 07, 2016, 09:46:58 AM »
ttechnik, roy_043 is right. You need to call "c:\GS\Ghostscript\bin\gswin64.exe" or rename "gswin64.exe" to "gs.exe".
ttechnik
« Reply #13 on: March 08, 2016, 02:51:52 PM »
THX to everyone
(command "shell"
    (strcat "d:/gs/gs918/bin/gswin64 \" -dBATCH -dNOPAUSE -q -sDEVICE=pdfwrite -iDirectories=d:/gs/gs918/bin
                 -sOutputFile=a.pdf b.pdf  \"")
gs is run, but:
Tamás Csepcsényi
« Reply #14 on: March 08, 2016, 03:01:18 PM »
ttechnik, Try the 32 bit version. The 32 bit version should run fine on an x64 machine.
roy_043
  • BricsCAD 18
« Reply #15 on: March 09, 2016, 03:01:22 AM »
@ ttechnik: You should supply the path to the PDFs. And to merge files you have to specify more than one source file.
  1.   (strcat
  2.     "D:/gs/gs918/bin/gswin64 "
  3.     "-dBATCH -dNOPAUSE -q -sDEVICE=pdfwrite -sOutputFile="
  4.     "D:/Test/merged.pdf D:/Test/a.pdf D:/Test/b.pdf"
  5.   )
  6. )
ttechnik
« Reply #16 on: March 09, 2016, 06:07:26 AM »
Not 64 bit problem.
Great difficulty solved problem.
The target must be complete file path.
Otherwise, not will create.
(command "shell"
    (strcat "d:/gs32/gs9.18/bin/gswin32 -dSAFER -dBATCH -dNOPAUSE -q -iDirectories=d:/gs32/gs9.18/bin
-sDEVICE=pdfwrite -sOutputFile=d:/gs32/gs9.18/bin/target.pdf a.pdf b.pdf  ")
« Last Edit: March 09, 2016, 06:11:09 AM by ttechnik »
Tamás Csepcsényi
ttechnik
« Reply #17 on: March 09, 2016, 07:39:29 AM »
What to do in the parameters, file names have spaces?
Tamás Csepcsényi
« Reply #18 on: March 09, 2016, 08:29:36 AM »
Will escaping the quote mark work?
... -sOutputFile=d:/gs32/gs9.18/bin/target.pdf \"a.pdf\" \"b.pdf\"
ttechnik
« Reply #19 on: March 09, 2016, 11:08:00 AM »
Not what I meant.
(command "shell"
    (strcat (findfile "gs/bin/gswin32.exe") " -dSAFER -dBATCH -dNOPAUSE -q "
                      "-iDirectories=" filesdir " -sDEVICE=pdfwrite "
                      "-sOutputFile=" outputfullfilename " " file1 " " file2)
file2 is "H:\\MT GPON 2015\\KM 002 Mezőkövesd dél (II) INS Turn Key\\__ReKód_13-14-15\\15\\dd-temp"
Which replace the space character strings?
Tamás Csepcsényi
ttechnik
« Reply #20 on: March 17, 2016, 11:22:45 AM »
Here is the solution:
(command "shell" (strcat (chr 34) "A:\\support_sajat\\prog_samples\\gs\\bin\\gswin32.exe "
"-dSAFER " "-dBATCH " "-dNOPAUSE " "-q " "-sDEVICE=pdfwrite " (chr 34)
"-sOutputFile=C:\\Users\\Tamás\\Dropbox\\F\\ss.pdf" (chr 34) " " (chr 34)
"C:\\Users\\Tamás\\Dropbox\\FTTH minták\\aa.pdf" (chr 34) " " (chr 34)
"C:\\Users\\Tamás\\Dropbox\\FTTH minták\\ss-temp.pdf" (chr 34)))
Tamás Csepcsényi
