Use an appropriate vla-add* function with the Block argument derived from the ObjectDBX Document to create your objects as opposed to using entmake(x) - see Example 1 from here for an example of how to accomplish this.
Hi Lee
Thanks for sparing time to reply.
I just want to assign an owner when making a new object or entity using entmakex.
I know that Using an appropriate
vla-add* function can do the job but,using
entmakex can obtain speed
more then
vla-add* the follow code is used in your Burstupgrade.lsp
(defun LM:burst:att2text ( enx )
(entmakex
(append '((0 . "TEXT"))
(LM:burst:removepairs '(000 002 070 074 100 280)
(subst (cons 73 (cdr (assoc 74 enx))) (assoc 74 enx) enx)
(defun LM:burst:matt2mtext ( enx )
(entmakex
(append '((0 . "MTEXT") (100 . "AcDbEntity") (100 . "AcDbMText"))
(LM:burst:remove1stpairs '(001 007 010 011 040 041 050 071 072 073 210)
(LM:burst:removepairs '(000 002 042 043 051 070 074 100 101 102 280 330 360) enx)
As you said,I got the Block argument (OwnrObj) derived from the ObjectDBX Document to create the owner objects,
then
(entmakex
(append (list '(0 . "TEXT") (cons 330 OwnrObj))
but the entities is in fact maked in the activedocument(etc. the drawing which run the lisp codes).
refer to the help topic
Examples
_$ (entmakex '((0 . "CIRCLE") (62 . 1) (10 4.0 3.0 0.0) (40 . 1.0)))
<Entity name: 1d45558>
Warning:
Objects and entities without owners are not written out to DWG or DXF files.
Be sure to set an owner at some point after using entmakex .
For example, you can use dictadd to set a dictionary to own an object.
So the questions are ,
how to handle this owners?
how to understand DXF code 330(soft pointer)and 360(hard pointer)?
If need to handle dictionary ,is there any example?
