Author Topic: Old lisp crashing 2016  (Read 2188 times)
DanB
« on: February 29, 2016, 10:39:41 AM »
I've had this LISP routine for quite some time. First use in 2016 is causing program to fatal error. I've tested a couple of times each crashes out. Any thoughts? (Snippet of error attached too.)
;;                       7/25/06                               ;;
;;        3d Polyline with User defined Elevations             ;;
;;    PROGRAM PROVIDED "AS IS" AND WITH ALL FAULTS,            ;;
;;    AND DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM   ;;
;;    WILL BE UNINTERRUPTED OR ERROR FREE.                     ;;
(defun c:3pe (/ oldecho oldos pnt1 elevz elev1txt elev1 pnt1e pntx elev2txt elevx) ;3pe
 (setq oldecho (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (setq pnt1 (getpoint "\nSpecify start point of polyline: "))
 (setq elevz (last pnt1))
 (if (/= elevz 0)
  (setq pe:elev1 elevz)
 (if pe:elev1
   (setq elev1txt (rtos pe:elev1 2 2))
   (setq elev1 (getreal (strcat "\nStart elevation: <" elev1txt "> ")))
    (if (= elev1 nil)
     (setq pe:elev1 pe:elev1)
     (setq pe:elev1 elev1)
  ) ;end progn
  (setq pe:elev1 (getreal "\nStart elevation: "))
 ) ;end if
 (setq pnt1e (subst pe:elev1 (last pnt1) pnt1))
 (command ".3dpoly")
  (while
   (if (= pntx nil)
     (setq oldos (getvar "osmode"))
     (setvar "osmode" 0)
     (command pnt1e)
     (setvar "osmode" oldos)
     (setq pntx (getpoint pnt1e "\nPick point: "))
    ) ;end progn
    (setq pntx (getpoint pntx "\nPick Point: "))
   ) ;end if
   (command pntx)
   (setq elev2z (last pntx))
   (if (/= elev2z 0)
    (setq pe:elev1 elev2z)
   (setq elev2txt (rtos pe:elev1 2 2))
   (setq elevx (getreal (strcat "\nElevation: <" elev2txt "> ")))
    (if (= elevx nil)
     (setq elevx pe:elev1)
     (setq elevx elevx)
   (setq pe:elev1 elevx)
   (setq pntx (subst elevx (last pntx) pntx))
   (command "undo")
   (setvar "osmode" 0)
   (command pntx)
  ) ;end while
 (command "")
 (setvar "cmdecho" oldecho)
squirreldip
Re: Old lisp crashing 2016
« Reply #1 on: February 29, 2016, 04:10:59 PM »
I don't get any error in C3D 2014...
Jeff_M
  • C3D user & customizer
« Reply #2 on: February 29, 2016, 04:25:14 PM »
It crashed my C3D2016 to the desktop. No error message, no CER, just "AutoCAD has stopped working" and gone. Now I've got a client coming in so no more time to troubleshoot.
« Reply #3 on: February 29, 2016, 05:18:44 PM »
Here's a quick rewrite - maybe this will resolve it:
  1. (defun c:3pe ( / cmd pt1 pt2 )
  2.     (if (setq pt1 (getpoint "\nSpecify start point: "))
  3.         (progn
  4.             (setq cmd (getvar 'cmdecho))
  5.             (setvar 'cmdecho 0)
  6.             (command "_.3dpoly" "_non" (setq pt1 (list (car pt1) (cadr pt1) (getelevation (caddr pt1)))))
  7.             (while (setq pt2 (getpoint pt1 "\nSpecify next point <exit>: "))
  8.                 (command "_non" (setq pt1 (list (car pt2) (cadr pt2) (getelevation (caddr pt2)))))
  9.             )
  10.             (command "")
  11.             (setvar 'cmdecho cmd)
  12.         )
  13.     )
  14.     (princ)
  15. )
  16. (defun getelevation ( def / tmp )
  17.     (or (and  3pe:elv (equal 0.0 def 1e-8))
  18.         (setq 3pe:elv def)
  19.     )
  20.     (if (setq tmp (getreal (strcat "\nSpecify elevation <" (rtos 3pe:elv 2 2) ">: ")))
  21.         (setq 3pe:elv tmp)
  22.     )
  23.     3pe:elv
  24. )
Jeff_M
« Reply #4 on: February 29, 2016, 06:09:48 PM »
That did function for me without crashing, Lee.  If I were to use this I would need to add a way to Close or eXit, but I don't think either of those were in the original anyway.
« Reply #5 on: February 29, 2016, 06:38:46 PM »
Excellent, thank you for testing it Jeff. :-)
Implementing your suggestions:
  1. (defun c:3pe ( / cmd lst pt1 pt2 )
  3.         (progn
  5.                   pt1 (list (car pt1) (cadr pt1) (getelevation (caddr pt1)))
  6.                   lst (list pt1)
  7.             )
  8.             (setvar 'cmdecho 0)
  9.             (command "_.3dpoly" "_non" pt1)
  10.             (while
  11.                 (progn
  12.                     (initget
  13.                         (strcat
  14.                             (if (cdr  lst) "Undo "  "")
  15.                             (if (cddr lst) "Close " "")
  16.                             "eXit"
  17.                         )
  18.                     )
  19.                     (cond
  20.                         (   (or
  21.                                 (vl-catch-all-error-p
  22.                                     (setq pt2
  23.                                         (vl-catch-all-apply 'getpoint
  24.                                             (list pt1
  25.                                                 (strcat
  26.                                                     "\nSpecify next point ["
  27.                                                     (if (cdr  lst) "Undo/"  "")
  28.                                                     (if (cddr lst) "Close/" "")
  29.                                                     "eXit] <eXit>: "
  30.                                                 )
  31.                                             )
  32.                                         )
  33.                                     )
  34.                                 )
  35.                                 (null pt2) (= "eXit" pt2)
  36.                             )
  37.                             (command "")
  38.                         )
  39.                         (   (= "Close" pt2)
  40.                             (command "_c")
  41.                         )
  42.                         (   (= "Undo" pt2)
  43.                             (command "_u")
  44.                             (setq lst (cdr lst)
  45.                                   pt1 (car lst)
  46.                             )
  47.                         )
  48.                         (   (listp pt2)
  49.                             (command "_non" (setq pt1 (list (car pt2) (cadr pt2) (getelevation (caddr pt2)))))
  50.                             (setq lst (cons pt1 lst))
  51.                         )
  52.                     )
  53.                 )
  54.             )
  55.             (setvar 'cmdecho cmd)
  56.         )
  57.     )
  58.     (princ)
  59. )
  60. (defun getelevation ( def / tmp )
  61.     (or (and  3pe:elv (equal 0.0 def 1e-8))
  62.         (setq 3pe:elv def)
  63.     )
  64.     (if (setq tmp (getreal (strcat "\nSpecify elevation <" (rtos 3pe:elv 2 2) ">: ")))
  65.         (setq 3pe:elv tmp)
  66.     )
  67.     3pe:elv
  68. )
DanB
« Reply #6 on: March 07, 2016, 03:57:39 PM »
Sorry for the delay in responding back. Thank you for getting this to work, quick test in 2016 and there's no crashing out.
« Reply #7 on: March 07, 2016, 05:49:18 PM »
Excellent to hear, hope the new code proves useful  :-)
krampaul82
« Reply #8 on: April 28, 2016, 11:58:04 AM »
You Rock!  Thank you for your numerous contributions to the lisp community!  I hope you win the lottery!
« Reply #9 on: April 28, 2016, 12:10:30 PM »
Thank you! - Now that would be something!  :lol:
MSTG007
« Reply #10 on: April 28, 2016, 02:49:31 PM »
Nice job!
Civil3D 2020
