// Proof of concept code 2016-02-29
// codehimbelonga kdub @ theSwamp
using System;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
[assembly
: CommandClass
(typeof(DimBlocks
.MyCommands))]
namespace DimBlocks {
public class MyCommands {
[CommandMethod("DoIt", CommandFlags.Modal)]
public void MyCommand() {
TM11();
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
"\n\n ====================================\n");
TM12();
private static void TM11() {
var doc = AcadApp.DocumentManager.MdiActiveDocument;
var db = AcadApp.DocumentManager.MdiActiveDocument.Database;
var ed = doc.Editor;
var arrowName = string.Empty;
// Get the current DIMBLK setting
arrowName = (string)AcadApp.GetSystemVariable("DIMBLK");
ed.WriteMessage($"\nDIMBLK is: {arrowName} \nID is: {db.Dimblk}\n");
// Set to '_OPEN'
AcadApp.SetSystemVariable("DIMBLK", "_OPEN");
// Set to default 'Closed filled'
db.Dimblk = ObjectId.Null;
// Set to '_DOT'
AcadApp.SetSystemVariable("DIMBLK", "_DOT");
// Set to '.'
AcadApp.SetSystemVariable("DIMBLK", ".");
ed.WriteMessage($"\nDIMBLK '.'is: {arrowName} \nID is: {db.Dimblk}\n");
private static void TM12() {
var dimBlockId = ObjectId.Null;
dimBlockId = GetDimBlockId("DIMBLK", "_DOTBLANK");
db.Dimblk = dimBlockId;
ed.WriteMessage($"\nDIMBLK is: {arrowName} \nID is: {dimBlockId}\n");
dimBlockId = GetDimBlockId("DIMBLK", ".");
ed.WriteMessage($"\nDIMBLK '.' is: {arrowName} \nID is: {dimBlockId}\n");
dimBlockId = GetDimBlockId("DIMBLK", "");
ed.WriteMessage($"\nDIMBLK '' is: {arrowName} \nID is: {dimBlockId}\n");
private static ObjectId GetDimBlockId(string dimBlkX, string newArrowName) {
ObjectId arrowObjId = ObjectId.Null;
if(string.IsNullOrEmpty(newArrowName)
|| newArrowName.Equals(".")) {
return ObjectId.Null;
var originalArrowName = (string)AcadApp.GetSystemVariable(dimBlkX);
// Force AutoCAD to add the block to the db.
AcadApp.SetSystemVariable(dimBlkX, newArrowName);
// Restore the previous setting
if(string.IsNullOrEmpty(originalArrowName)) {
else {
AcadApp.SetSystemVariable(dimBlkX, originalArrowName);
using(Transaction tr = db.TransactionManager.StartTransaction()) {
var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
arrowObjId = bt[newArrowName];
tr.Commit();
return arrowObjId;
public class InitMyCommands : Autodesk.AutoCAD.Runtime.IExtensionApplication {
public void Initialize() {
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n\t\t\t*** type DOIT to run test \t***");
public void Terminate() {
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Cleaning up...");
