My reason for asking this, is a need to produce an Address Plan for a subdivision, which shows both the Lot Number (for Plat), and the Address number.
My employer wants this to look a certain way - where both numbers are aligned with the lot (plan readable), which means perpendicular / radial to the parent Alignment.
No Parcel Label orientation settings allow for this, without manually rotation each-and-every-single Label, and even then, only after duplication each-and-every-single Area Label as Face Label. Grrr
The only other Parcel-based solution, is to duplicate the Parcels in a secondary Site, and renumber those as Address number, because the Address Property isn't exposed or able to be populated en-mass via UI. Grrr
Even then, I couldn't find a way to save an increment of 4 instead of 1, within the renumber settings, which the County requires. There may be a way, I just couldn't find it. Grrr. Further, I'd now need another Label Style to align both Labels, lot above the address number, which means quadrupling the manual effort - Create/renumber the Parcels, create face labels, then rotate them all accordingly.
So instead, I ended up exporting to AutoCAD, and then used some LISP routines to quickly move each Lot Number to centroid of the lot's respective setback envelope (thank you SincPac!), and rotate perpendicular / radial to the Alignment (which isn't selectable using nested selection LispFunctions!? Grrr again). Another routine to prompt me for starting Address number and increment, then just pick pick pick to append to the now MText Lot Number labels, and done.
