Author Topic: 2 point cursor window  (Read 2636 times)
LSElite
« on: February 01, 2016, 05:23:55 PM »
Hey All
I want a simple user input where they can input 2 points.
when the second point is input it will draw a rectangle between the 2 points.
I also want it to have an angle value so the rectangle will be shown on an angle between the 2 points.
The only output I want back is the 2 points, I just want the rectangle graphic as clarity for the user.
Cheers
“A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing.”
― George Bernard Shaw
ymg
Re: 2 point cursor window
« Reply #1 on: February 01, 2016, 06:30:53 PM »
How about draw a rectangle with lisp.
Then get the bounding box, that will be your 2 points.
then erase the rectangle.
  1. (defun c:test (/ en obj p1 p2)
  2.    (command "_RECTANGLE" pause pause)
  3.    (setq en  (entlast)
  4.          obj (vlax-ename->vla-object en)
  5.    )
  6.    (vla-getboundingbox obj 'minpt 'maxpt)
  7.    (setq p1 (vlax-safearray->list minpt)
  8.          p2 (vlax-safearray->list maxpt)
  9.    )
  10.    (entdel en)
  11.    (princ)
  12. )
  13.
ymg
« Last Edit: February 01, 2016, 06:43:40 PM by ymg »
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: February 01, 2016, 06:39:30 PM »
You like fries with that ??
do you know the angle before you start ?
what is the lifetime of the rectangle ?
Will this only be used in world UCS Top view ?
Called Kerry in my other life
I live at UTC + 13.00
LSElite
« Reply #3 on: February 01, 2016, 07:41:15 PM »
No, A simple point in the right direction would do.
I apologize I had to write the post in a rush before I ran off to work.
I've tried looking into grdraw but I cant figure out how to make it work.
Other than that I don't have the slightest idea on how to approach it.
The angle information would be an independent setting defaulting to 0 if unchanged.
Rectangle is temporary for selection purposes to identify the space being picked.
The UCS will be Top down World.
ymg, thats a clever work around, I will have a tinker with it later.
Any ideas?
« Last Edit: February 01, 2016, 07:48:56 PM by LSElite »
kdub_nz
  • SuperMod
« Reply #4 on: February 01, 2016, 07:58:24 PM »
These seem contradictory.
Do you want to use the rectangle for selection ?
If you draw a temporary rectangle at an angle ( for visualisation ) and return the 2 corner points how do you propose making a selection using the 2 points ?
added warning note:
a getboundingbox call will return the total area covered by the object ie: a rectangle with sides normal to the X and Y ordinates.
« Last Edit: February 01, 2016, 08:06:07 PM by kdub »
LSElite
« Reply #5 on: February 01, 2016, 08:32:51 PM »
You are right, I am sorry for the lack of clarity.
Some times information is missed in the rush of everyday life, I will take more care in the future.
Here is a comprehensive description:
I have a sprinkler array routine which involves selecting 2 points in the corners of a rectangular space.
It associates these points to a rectangular space and uses this to calculate the required number of sprinklers for said space.
It then arrays sprinkler blocks in a compliant layout around the space.
(Note the space is a merely data created by the 2 points, the only physical entities being made are the sprinklers.)
I want to make the routine more user friendly by providing a preview box around the 2 points while selecting.
The rectangle needs to have a set angle depending on angle of the room being picked.
The user will input the angle at an earlier stage to picking the points.
kdub_nz
  • SuperMod
« Reply #6 on: February 01, 2016, 09:04:10 PM »
I have  work to finish.
I can have a look at some options in couple of hours.
kdub_nz
  • SuperMod
« Reply #7 on: February 01, 2016, 11:51:16 PM »
Try something like this/these
  1. (defun c:DoIt02 (/ RotAngle p0 Px OppCorner)
  2.   (setq p0 (getpoint "\nSelect Rectangle Corner:"))
  3.   (setq px (getpoint p0 "\nSelect Point on Adjacent Side:"))
  4.   (setq RotAngle (/ (* (angle P0 Px) 180.0) pi))
  5.   (setq OppCorner (test01 p0 RotAngle))
  6.   (print OppCorner)
  7.   (princ)
  8. )
  9.
  10.
  11. ;;====================================
  12. (defun c:DoIt01 (/ RotAngle p0 OppCorner)
  13.   (setq RotAngle 15.0)
  14.   (setq p0 (getpoint "\nSelect Lower Left Corner"))
  15.   (setq OppCorner (test01 p0 RotAngle))
  16.   (print OppCorner)
  17.   (princ)
  18. )
  19.
  20.
  21. ;;====================================
  22.
  1. (defun test01 (p0         RotDegreeAngle
  2.                /          done
  3.                color      rotang
  4.                grreturn   cursorPoint
  5.                returnval  p1
  6.                p2         p3
  7.                _drawrect
  8.               )
  9.   (princ "\nSelect Upper Right Corner: ")
  10.   (setq color  3                                       ;(acad_colordlg 3 nil)
  11.         rotang (* (/ RotDegreeAngle 180.0) pi)
  12.   )
  13.   ;;-----
  14.   (defun _drawrect (col / diagAng diag localAng)
  15.     (setq p2       cursorPoint
  16.           diagAng  (angle P0 p2)
  17.           diag     (distance P0 p2)
  18.           localAng (- diagAng rotang)
  19.           p1       (polar p0 rotang (* diag (cos localAng)))
  20.           p3       (polar p2 rotang (- (* diag (cos localAng))))
  21.     )
  22.     (grdraw p0 p1 col)
  23.     (grdraw p1 p2 col)
  24.     (grdraw p2 p3 col)
  25.     (grdraw p3 p0 col)
  26.   )
  27.   ;;-----
  28.   (while (not done)
  29.     (setq grreturn (vl-catch-all-apply 'grread '(t 12 0)))
  30.     (cond ((vl-catch-all-error-p grreturn)             ; oOOOOOPS
  31.            (setq done t
  32.                  returnval nil
  33.            )
  34.           )
  35.           ((= (car grreturn) 5)                        ;Moved Mouse cursor
  36.            (if cursorPoint
  37.              (redraw)
  38.            )
  39.            (setq cursorPoint (cadr grreturn))
  40.            (_drawrect color)
  41.           )
  42.           ((= (car grreturn) 3)                        ;Left Mouse button
  43.            (setq done      t
  44.                  returnval (cadr grreturn)
  45.            )
  46.            (redraw)
  47.           )
  48.           ((or (and (= (car grreturn) 2)
  49.                     (vl-position (cadr grreturn) '(13 32))
  50.                                                        ;Enter/SpaceBar
  51.                )
  52.                (= (car grreturn) 25)                   ;Right Mouse button
  53.            )
  54.            (setq done t
  55.                  ;; returnVAL (car grReturn)
  56.                  returnval
  57.                   nil
  58.            )
  59.            (redraw)
  60.           )
  61.     )
  62.   )
  63.   returnval
  64. )
  65.
  66.
Video http://screencast.com/t/eJJ8MZbc9Em
« Last Edit: February 02, 2016, 12:13:58 AM by kdub »
LSElite
« Reply #8 on: February 02, 2016, 12:42:39 AM »
Awesome stuff mate.
I had a quick look and it looks perfect.
Cheers
kdub_nz
  • SuperMod
« Reply #9 on: February 02, 2016, 12:49:53 AM »
I'm Pleased to be able help Matthew.
LSElite
« Reply #10 on: February 02, 2016, 05:23:39 AM »
He knows my name :O.
I feel my power draining...
LSElite
« Reply #11 on: February 02, 2016, 07:12:15 AM »
Hey kdub
Thanks again, the code works well.
It took a bit of reverse engineering to wrap my head around it.
Working with input devices is very much new ground for me.
2 things I would like to add in are:
Object snap functionality.
The ability to change the angle while picking the second point, just incase the user changes their mind.
I am going to give it a go tomorrow night.
Any advice in the meantime would be appreciated.
« Reply #12 on: February 02, 2016, 10:18:52 AM »
There is also THIS routine for drawing rotated rectangles.
« Reply #13 on: February 02, 2016, 12:15:44 PM »
This may also be of some help: 3-Point Rectangle
LSElite
« Reply #14 on: February 02, 2016, 05:04:10 PM »
Cheers fellas, they are not exactly what I need but are great resources to help get me there.
Thanks for the help :)
