Author Topic: Inserting block in area at equal distance.  (Read 1656 times)
HasanCAD
« on: February 01, 2016, 07:27:10 AM »
Is there such as a lisp to do this task?
irneb
Re: Inserting block in area at equal distance.
« Reply #1 on: February 01, 2016, 08:04:51 AM »
Have you tried the Express Tools - SuperHatch? It can "array" such block within a boundary at specified distances and starting position.
HasanCAD
« Reply #2 on: February 01, 2016, 10:01:13 AM »
It is good idea
But supper hatch fives a fixed number which is (4000mm) and will not give an equal distances.
This arrangement for MEP people who need to put Fire Fighting equipment.
« Last Edit: February 01, 2016, 10:06:51 AM by HasanCAD »
irneb
« Reply #3 on: February 01, 2016, 11:10:25 AM »
Really? That's just the default: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-89FB15FE-28B9-4A51-BACA-A393469EE1A6-htm.html
Note the sequence for using blocks: (1) Insert point of first block. (2) scale factor. (3)Rotation. (4) "Window around" for spacing distance ...
That last one defaults to the bounding box of the block you used, but you can specify any size you want.
