Author Topic: Auto Click with Nearest  (Read 1804 times)
MSTG007
« on: January 28, 2016, 08:40:25 AM »
If I have a Survey Xref that I need to trace a line that has a lot of vertexes. I want to be able to click at a starting point then follow the line with my cursor where it auto snaps (clicks) until I select the last point where it ends.
Civil3D 2020
Re: Auto Click with Nearest
« Reply #1 on: January 28, 2016, 09:31:10 AM »
« Reply #2 on: January 28, 2016, 09:33:55 AM »
ncopy  x10
« Reply #3 on: January 28, 2016, 09:35:42 AM »
or  let me ask,  is this
A) a contour line
B) a figure  line?
there might be a best way to get that object in your current file depending on what it is?
for contour line  >>>  use EXTRACT object
for Figure  >>> Insert to current file from survey toolspace
MSTG007
« Reply #4 on: January 28, 2016, 09:47:58 AM »
It is not a Feature Line. Its not a contour. Its usually existing line work I have to trace and place on its own layer. So I thought I might be able to select the layer (demo) that I want, then trace over the curb or whatever I want. Usually when we trace it, we CLICK each ENDPOINT. A lot of CLICKS... Is it lazy to click less?
Civil3D 2020
« Reply #5 on: January 28, 2016, 09:58:28 AM »
linework...AKA  it should be a survey FIGURE and then you would NEVER have to trace again
make use of the survey toolspace....
create figure from object command...
then the figure(s) is portable
« Reply #6 on: January 28, 2016, 10:44:08 AM »
