Author Topic: Attach External Reference Dialogue Box  (Read 2208 times)
MSTG007
« on: January 27, 2016, 10:49:23 AM »
Dumb question, Is there a variable to just have AutoCAD Attach an Xref without showing the "Attach External Reference" Box (Where you have to click OK Button) to attach it?
Civil3D 2020
Rob...
Re: Attach External Reference Dialogue Box
« Reply #1 on: January 27, 2016, 10:54:12 AM »
How would you like to go about attaching it?
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #2 on: January 27, 2016, 10:56:28 AM »
Use "-xref" to use the command line and bypass the dialog box.
Autodesk Expert Elite
« Reply #3 on: January 27, 2016, 11:06:41 AM »
turn off file and command dialog boxes
cmddia=0
filedia=0
MSTG007
« Reply #4 on: January 27, 2016, 11:16:44 AM »
I usually just use the "XA" Command. then browse for the file. (I did not know if I could just do that without the box and hitting the OK button. Its no bid deal, I was just doing what I do to much.... ask to much. lol.
Civil3D 2020
« Reply #5 on: January 27, 2016, 11:42:44 AM »
You can also drag n drop with the right mouse button.
MSTG007
« Reply #6 on: January 27, 2016, 11:44:41 AM »
Ok. that is the most coolest easiest way I have ever seen. I never knew that. That my friend is sweet.
Civil3D 2020
« Reply #7 on: January 27, 2016, 11:57:12 AM »
:)  The only downside is you cannot attach multiple files at once like this.
MSTG007
« Reply #8 on: January 27, 2016, 12:02:45 PM »
Just another little thing I found out, When it brings it in, it seems that its an ATTACHMENT not OVERLAY.
Civil3D 2020
« Reply #9 on: January 27, 2016, 12:08:53 PM »
That is strange that it does not honor the XREFTYPE variable.  :(
MSTG007
« Reply #10 on: January 27, 2016, 12:10:59 PM »
Still not the end of the world if it does not change. Just need to be aware of it. Still quicker than the other ways....
Civil3D 2020
