Has anyone had any problems exporting sheet files to generic AutoCAD DWG? Lately when we try to export a sheet file that has several xrefs (Without Civil3D Data) and all the Civil3D Data is Referenced inside the sheet; it bombs out. So we have to bind each file into the sheet file until we find the one that is messed up and audit, etc.
The other question I have to this is, when you export how can you just export the entities objects that are on and not those that are off or frozen? I know you can do that by WBLOCK but I do not know how that would work with a title block within paperspace.
