Disclaimer, we've just started using Revit. In MEP we divide the floor up into areas for our spool drawings. So in Revit I'm trying to use Areas for this same division.
Firstly, how can I get all the elements within an Area? Since Area isn't a parameter on elements I'm assuming there isn't a way to use a FilteredElementCollector.
Secondly, is there a better way to divide a drawing up into "Areas" and then query all the pipe, pipe fittings, and pipe accessories?
