Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Getting autocad vertical information
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Getting autocad vertical information (Read 1497 times)
sdunn
Newt
on:
January 20, 2016, 06:43:57 PM »
I am looking for an automated way in .net to obtain the service pack version of Civil 3D 2013 and newer.
I found where I can get the application version but not the service pack information. Am I limited to searching the registry?
Logged
sdunn
Newt
Re: Getting autocad vertical information
Reply #1 on:
January 25, 2016, 07:29:45 PM »
Thanks to Jeff for this:
http://forums.autodesk.com/t5/autocad-civil-3d-customization/find-the-current-service-pack-version-of-civil-3d/td-p/6000264
I came up with something in lisp that works for 2015.
Code - Auto/Visual Lisp:
[Select]
defun
c:getinfo
vl-load-com
cond
setq
wscript
vlax-create-object
"WScript.Network"
setq
pcname
vlax-get-property
wscript
"ComputerName"
pcdom
vlax-get-property
wscript
"UserDomain"
pcuser
vlax-get-property
wscript
"UserName"
vlax-release-object
wscript
; cond
; get civil 3d service pack info from registry
setq
reg
strcat
"HKEY_LOCAL_MACHINE
vlax
machine
product
key
setq
reg
strcat
substr
reg
1
Service Packs"
setq
reg
strcat
reg
car
vl-registry-descendents
reg
setq
PatchTitle
vl
registry
read
reg
"PatchTitle"
setq
Release
vl
registry
read
reg
"Release"
; Get ram using doslib
setq
maj
itoa
atoi
getvar
"acadver"
setq
dls
strcat
"doslib"
maj
".arx"
setq
res
dos_mem
setq
mem
rtos
nth
1
res
2
0
setq
memgb
read
mem
1048576
mapcar
princ
list
\n
Computername: "
pcname
\n
User domain: "
pcdom
\n
User name: "
pcuser
\n
Service Pack: "
PatchTitle
\n
Release: "
Release
\n
Total Physical Memory: "
memgb
princ
Logged
huiz
Swamp Rat
Certified Prof C3D
Reply #2 on:
January 26, 2016, 03:33:09 AM »
Gile wrote an excellent function to find information about installed versions:
http://www.theswamp.org/index.php?topic=31867.msg538136#msg538136
Maybe that will help you.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
