While add second line to text the line in between disappear
or one could do this as a SUFFIX with MIN being on same line as dimension string.
Quote from: HasanCAD on January 12, 2016, 02:29:58 PMWhile add second line to text the line in between disappearDid you try adding <>\XMIN (which puts "MIN" below the dim line
I've noticed that if the text is not in home position, the gap appears.
@HasanCAD: What are your values for:DIMTADDIMGAPDIMTVPDIMTFILL (text fill, see tedg's remark)
DIMTAD = 1DIMGAP = 1DIMTVP = 0DIMTFILL = 0
This works (at least in BricsCAD):1.Restore the position of the dimension text (_DIMEDIT).2.Use '\X' instead of '\P' to start the new line.
