Author Topic: DimText hide Dimlines  (Read 3581 times)
HasanCAD
« on: January 12, 2016, 02:29:58 PM »
While add second line to text the line in between disappear
« Last Edit: January 13, 2016, 06:00:40 AM by HasanCAD »
tedg
Re: DimText delete Dimlines
« Reply #1 on: January 12, 2016, 02:35:28 PM »
Did you try adding <>\XMIN (which puts "MIN" below the dim line
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
tedg
« Reply #2 on: January 12, 2016, 02:36:36 PM »
Unless this is text wipe-out thing, not sure you can work around that (without removing the background mask in the dim style).
« Last Edit: January 12, 2016, 02:43:02 PM by tedg »
danallen
« Reply #3 on: January 12, 2016, 02:38:43 PM »
I've noticed that if the text is not in home position, the gap appears.
« Reply #4 on: January 12, 2016, 02:57:18 PM »
or one could do this as a SUFFIX with MIN being on same line as dimension string.
tedg
« Reply #5 on: January 12, 2016, 03:04:20 PM »
+1
[side note]
I do that allot, create a special dim style with a common prefix or suffix (either beside or below) for plus/minus or "(e)" for existing, etc.
Beats add that to all the dimensions involved.
[/side note]
roy_043
  • BricsCAD 18
« Reply #6 on: January 12, 2016, 04:20:31 PM »
@HasanCAD: What are your values for:
DIMTAD
DIMGAP
DIMTVP
DIMTFILL (text fill, see tedg's remark)
HasanCAD
« Reply #7 on: January 13, 2016, 03:15:38 AM »
Not Working
In some cases working.
I am adding this second line for some dimension not all.
DIMTAD
DIMGAP
DIMTVP
DIMTAD = 1
DIMGAP = 1
DIMTVP = 0
DIMTFILL = 0
roy_043
  • BricsCAD 18
« Reply #8 on: January 13, 2016, 03:27:43 AM »
DIMTAD = 1
DIMGAP = 1
DIMTVP = 0
DIMTFILL = 0
I can't reproduce the issue with those settings (note: I use BricsCAD).
Can you post a dwg?
HasanCAD
« Reply #9 on: January 13, 2016, 04:19:27 AM »
Attached
roy_043
  • BricsCAD 18
« Reply #10 on: January 13, 2016, 04:57:47 AM »
This works (at least in BricsCAD):
1.
Restore the position of the dimension text (_DIMEDIT).
2.
Use '\X' instead of '\P' to start the new line.
tedg
« Reply #11 on: January 13, 2016, 07:36:57 AM »
1.
2.
Yes, that is what I was saying, and it works in AutoCAD too.
There is a right-click option to "Reset Text Position" too
HTH
