Author Topic: Delay With Commands (Performance of a drawing)?  (Read 2717 times)
MSTG007
« on: January 12, 2016, 08:02:20 AM »
Ok I have one more for you. I have noticed more recently that when I select the a hatch that it takes a few milliseconds to actually select it in some of my drawings. Within those the drawings I have selected a entity and then have to wait a few milliseconds for my cursor to move, in order to grip the object. I have also tried closing the ribbon and all the other palettes and still get the same results.
Is just my machine? lol.
Civil3D 2020
Rob...
Re: Delay With Commands (Performance of a drawing)?
« Reply #1 on: January 12, 2016, 08:15:11 AM »
It could be your machine but it also can be a number of things having to do with something in the files. You mention hatches. Large areas of hatch or complicated boundaries could cause that. Using an XREF as a hatch boundary can also do that. Another good one is un-associated attributes in an XREF. I've seen a single one bring a drawing to a crawl. Point is that it is hard to narrow it down without a file.
Can you post a problem file?
CAD Tech
MSTG007
« Reply #2 on: January 12, 2016, 08:18:55 AM »
Interesting. Ok. I think its more of a machine thing now, Just because I closed ACAD Completed, waited a few seconds and started back up. I then reopened the file and its like its normal again. I am going to guess a RAM thing?
Civil3D 2020
Rob...
« Reply #3 on: January 12, 2016, 08:24:49 AM »
A restart can clear some temporary issues, like your cache getting full. Do you restart on a regular basis?
How about computer maintenance? Delete files from temp folders, defrag (if you are not using an SSD), virus and malware scans, etc.
Is that stuff done a regular basis?
CAD Tech
MSTG007
« Reply #4 on: January 12, 2016, 08:29:14 AM »
Yup. These our IT Dept does a great job of maintaining our systems.
Civil3D 2020
Rob...
« Reply #5 on: January 12, 2016, 08:32:07 AM »
You might want to try turning off hardware acceleration and see if that helps.
CAD Tech
MSTG007
« Reply #6 on: January 12, 2016, 08:34:19 AM »
Could I ask an off the wall question. What is your thoughts with the AutoCAD and READYBOOST? Think that helps any or not worth it? I will try the hardware acceleration and see what we get.
Civil3D 2020
Rob...
« Reply #7 on: January 12, 2016, 08:36:23 AM »
Sorry, don't know anything about that.
CAD Tech
« Reply #8 on: January 12, 2016, 10:12:49 AM »
Just get an SSD .. IMO that's one of the biggest performance boosters.
« Reply #9 on: January 12, 2016, 04:42:28 PM »
are you using INDEXCTL? and his cousins to your advantage?
and or settings check on SORTENTS
« Reply #10 on: January 13, 2016, 01:01:48 AM »
That's like saying you should defrag your hard drive... Get an SSD if you're still running spinny  :angel:
