Maybe you can try this posted here :http://www.theswamp.org/index.php?topic=49959.0But I suppose it'll be also quirky, but test it, you'll never know...
Hi,Yes I noticed this behaviour which is not due to the mextrude LISP but to the way the AutoCAD extrusion works with non planar paths (the native _SWEEP command gives the same result).To to what you want, you have to use the _LOFT command.
Hi,This is a quite old LISP which dispach a profile (section) along a path.The profile must be a block containing a single planar entity oriented so that its X axis will be aligned to the path tangents (see the example in the attached dwg file.A little video.
