Author Topic: Upgraded windows 7 to 10  (Read 2405 times)
Jeff H
« on: November 21, 2015, 09:05:31 pm »
I have done something wrong.
It took a little while to upgrade but once done I had to restart and have had no issues, errors, performance degradation, etc...
I had to spend 5 to 10 minutes googling a couple things to see where it was or how to handle something but everything has been easy to figure out even with it looking different.
What did I do wrong? I thought
google would be blocked
no start menu
mouse and keyboard would not work
could not figure out new interface that looks almost the same
etc.....
I will keep trying to see if I cant make it work like everyone told me it should.
Re: Upgraded windows 7 to 10
« Reply #1 on: November 21, 2015, 09:13:14 pm »
you're playing with my head, I'm confused.
are you bitching at us  because it worked ??
--> Donate to theSwamp<--
Jeff H
« Reply #2 on: November 21, 2015, 09:58:08 pm »
Had a couple of people tell me how bad windows 10 was and how all these bad things happened, but my experience was good and like it so far.
Was just joking that some people expect it to be so bad and those are usually the loudest.
BlackBox
« Reply #3 on: November 22, 2015, 02:04:47 am »
I've had similar experience, and rather like Win10's performance gains over Win8.1 (which also was a good OS upgrade to Win7, IMO [we're ignoring Win8, or at least filing that with WinVista, that flaming pile of puss]).
I've only had one issue so far, and for the life of me cannot see how it's Win10's fault (methinks it either network latency, or Autodesk causing it, but did not have this issue with Win8.1 using same version of C3D, on same hardware.
 http://www.theswamp.org/index.php?topic=50185.0
"Potential has a shelf life." - Margaret Atwood
MickD
  • I don't need a job, I need Money!!
« Reply #4 on: November 22, 2015, 02:07:39 am »
Yep. I've been using it for a few months now and it's fine.
I had one major (not that bad) problem with my sound but with a bit of searching found a driver fix.
It's pretty much the same, boots up a bit quicker and I like the look of the window theme.
The new start menu is probably the biggest change and may throw some people but it's not un-workable.
"A language that doesn’t have everything is actually easier to program in than some that do."
        — Dennis M. Ritchie
BlackBox
« Reply #5 on: November 22, 2015, 04:10:16 am »
Start menu now has Win7-like 'menu' style, or Win8.1-like full screen. I also like the option to have a main task bar (with everything), and secondary/tertiary apps only show on their respective monitor.
Only common functionality that's been removed that I wish hadn't, is the ability to drag sort pinned files. Grrr
« Reply #6 on: November 22, 2015, 04:26:42 am »
I updated 6 of the 7 machines here at home.
No issues technically ; usual PEBCAK issues of the nature "but it's different ... "
Fortunately I missed the 8.1 experience.
BlackBox
« Reply #7 on: November 22, 2015, 12:55:48 pm »
8.1 was/is a good OS (and what Server 2012 R2 is built on) - 8 was grossly different from 8.1, and cumbersome to work with.
Most incorrectly thought 8.1 was an 'update' to 8, when in fact it was s different OS altogether (and free to anyone with 8 ); horrible branding/marketing decision on MS' part.
BlackBox
« Reply #8 on: November 25, 2015, 02:19:29 pm »
Something I noticed just yesterday about Win10, more specifically as it relates to Office 2013 ProPlus (O365, automatically updated, 2016 ProPlus is being installed next week) - is that Start, All Apps icon, Microsoft Office 2013 folder only contains Outlook.
OneNote is down under the letter "O" heading, but Access, Excel, Publisher, Powerpoint, and Word etc. are nowhere to be found.
Start, then typing "Word" doesn't even pull up Office's Word application.
I ended up having to navigate to C:\Program Files\Microsoft Office 15\root\office15 via Explorer to pin apps to Start/Taskbar accordingly. Grrr
Separately, I'm also bummed that the all apps column (that comes onto screen from left, out of view), is not resizeable, regardless of using Start in menu or full screen form.
That being said, 'Autodesk AutoCAD Civil...' is all that I can see from the Start, All Apps view... Glad I use pinned apps instead, with multiple versions of IDSP installed.  :-D
MickD
« Reply #9 on: November 25, 2015, 03:31:17 pm »
Yep, I meant to mention that about the 'missing' apps as well, can be quite annoying. Pinning to start bar doesn't work either so I've had to resort to desktop short cuts or pin to task bar. :(
That's probably the worst annoyance I have noticed though.
        — Dennis M. Ritchie
« Reply #10 on: November 25, 2015, 07:12:01 pm »
So here's a technical question for those that have already upgraded ....
My new machine will come with Win10 x64 installed, but I need to run VS 2012 and AutoCAD 2014+. I can downgrade to Win7 if needed.
What issues should I expect, if any?
BlackBox
« Reply #11 on: November 27, 2015, 12:42:12 am »
I cannot speak to VS 2012, as I've been using VS 2015 since Win8.1, however I have been using IDSP (mostly C3D) 2015 since upgrading to Win10.
Generally speaking, everything seems to perform better under Win10.
The only CAD-specific issue I've experienced since, and I'm still not certain it's the fault of CAD on Win10 (methinks it a network latency issue, with too many users streaming), is linked above in post #3 of this thread.
Cheers
Greg B
  • Tell me a Joke!
« Reply #12 on: November 27, 2015, 09:12:44 am »
Shouldn't you be able to set the executable to Run As Windows 7?
« Reply #13 on: November 27, 2015, 09:47:05 am »
You might think .. but I've had issues with compatibility settings on other applications. Why should I think the Win 10 compatibility settings would be any different?
Greg B
  • Tell me a Joke!
« Reply #14 on: November 27, 2015, 12:54:16 pm »
Understandable.   I had a client that purchased a new computer with Windows 10 and while the program they typically used worked on 10 initially, it developed problems.  Once I set it to run as windows 7, I have not heard of a problem since.
I know that is only one case, but it is more than 0 cases.
