Author Topic: Simulate click on toolbar  (Read 11458 times)
roy_043
  • BricsCAD 18
Re: Simulate click on toolbar
« Reply #15 on: November 11, 2016, 05:59:45 AM »
@lamarn:
Not exactly what you want but here is a MODEMACRO solution that will display the osnaps in the status bar:
(setvar "MODEMACRO"
  (strcat
    "$(if,$(=,$(getvar,OSMODE),0),** OSNAPS OFF ** ,)"
    "$(if,$(=,$(and,$(getvar,OSMODE),    1),0),,END )"
    "$(if,$(=,$(and,$(getvar,OSMODE),    2),0),,MID )"
    "$(if,$(=,$(and,$(getvar,OSMODE),    4),0),,CEN )"
    "$(if,$(=,$(and,$(getvar,OSMODE),    8),0),,NOD )"
    "$(if,$(=,$(and,$(getvar,OSMODE),   16),0),,QUA )"
    "$(if,$(=,$(and,$(getvar,OSMODE),   32),0),,INT )"
    "$(if,$(=,$(and,$(getvar,OSMODE),   64),0),,INS )"
    "$(if,$(=,$(and,$(getvar,OSMODE),  128),0),,PER )"
    "$(if,$(=,$(and,$(getvar,OSMODE),  256),0),,TAN )"
    "$(if,$(=,$(and,$(getvar,OSMODE),  512),0),,NEA )"
    "$(if,$(=,$(and,$(getvar,OSMODE), 1024),0),,GCE )" ; Geometric center (BricsCAD).
    "$(if,$(=,$(and,$(getvar,OSMODE), 2048),0),,APP )"
    "$(if,$(=,$(and,$(getvar,OSMODE), 4096),0),,EXT )"
    "$(if,$(=,$(and,$(getvar,OSMODE), 8192),0),,PAR )"
    "$(if,$(=,$(and,$(getvar,OSMODE),16384),0),,** OSNAPS OFF ** )"
« Reply #16 on: November 11, 2016, 08:24:02 AM »
Assuming I've understood the request, this thread may be of interest.
MSTG007
« Reply #17 on: November 11, 2016, 08:37:11 AM »
I am still trying to understand this. Is the object for the user to hoover there mouse over the icon and the command in the icon activates?
Civil3D 2020
Marc'Antonio Alessi
  • Marco
« Reply #18 on: November 11, 2016, 08:58:59 AM »
@lamarn:
(setvar "MODEMACRO"
  (strcat
Maybe this is simple:
(defun sample ( / CurStr)
  (setq CurStr "")
  (mapcar
           '(lambda (x s)
              (if (= (logand x (getvar "OSMODE")) x) (setq CurStr (strcat CurStr s)))
           '(1 2 4 8 16 32 64 128 256 512 2048)
           '("_Endpoint," "_Midpoint," "_Center," "_Node," "_Quadrant," "_Intersec," "_Insert,"
             "_Perpend,"  "_Tangent,"  "_Nearest,""_Appint,"
  (setvar "USERS5" (strcat " " (substr CurStr 2 (- (strlen CurStr) 2)) "."))
  (setvar "MODEMACRO" "[$(getvar,users5)]")
roy_043
  • BricsCAD 18
« Reply #19 on: November 11, 2016, 09:59:57 AM »
Your suggestion only displays the current settings in the statusbar. My suggestion will update automatically whenever the osmode changes.
lamarn
« Reply #20 on: November 11, 2016, 10:32:03 AM »
I was thinking more about a OpenDCL approach. Found a a modeless form has what i am looking for..
http://www.opendcl.com/forum/index.php?topic=2446.msg12208#msg12208
Marc'Antonio Alessi
  • Marco
« Reply #21 on: November 11, 2016, 11:04:53 AM »
You're right, I apologize. I change the osnaps only with a specific function...
hmspe
« Reply #22 on: November 11, 2016, 11:28:43 AM »
AcadStatButton available from manusoft.com in the Freebies/Miscellaneous tab will let you add buttons to the status bar which will toggle.  I have attached the lisp file I used with AcadStatButton before I switched to Bricscad.
lamarn
« Reply #23 on: November 11, 2016, 12:37:10 PM »
Thanks so much Richard and all of you guys!
This is looking promising.. To me the great value of the forum community to share and combine ideas is a real fact!!
roy_043
  • BricsCAD 18
« Reply #24 on: November 12, 2016, 03:49:54 PM »
FWIW: I have posted an ODCL-based solution here.
lamarn
« Reply #25 on: November 13, 2016, 05:14:55 PM »
Lets discuss this Opendcl sollution furhter on there.
But here is a screenshot i am happy to share ..! nice job, all credits to you mr. Roy_043
I am very thankful for your help getting this on track..!  :-D
*EDIT* updated a gif
« Last Edit: November 16, 2016, 04:13:50 PM by lamarn »
lamarn
« Reply #26 on: November 16, 2016, 04:14:51 PM »
Credits to mr. Roy_04 for making this fine piece of machine buttons .. :wideeyed2:
lamarn
« Reply #27 on: January 16, 2017, 05:01:11 PM »
Hi
I'm trying to come up with a toggle (refresh) button..
The main .lsp is OpenDcl and this if functions calls a subroutine, this seem to work
Any experience idea to make this more elegant or how this can work better much appriciated.
Even better would be is the toolbar was to come just by pressing F3, but that would need some kind of reactor..
** EDIT
By Using  (progn (load "Osnaps") (dcl-Form-Close Osnaps/Main) ())) it supresses the OpenDCL warning
; "Osnaps" by Roy_043
http://www.opendcl.com/forum/index.php?topic=2446.msg12212#msg12212
(defun c:Tbar_osnap ()
    (setvar "userr1"
        (abs
            (1-
                (getvar "userr1")
  (setq tbmode (rtos (getvar "userr1") 2 0))
  (if (= tbmode "1")
    (load "Osnaps") ())
  (if (= tbmode "0")
     (progn (load "Osnaps") (dcl-Form-Close Osnaps/Main) ())) ; ** EDIT **
« Last Edit: January 17, 2017, 02:45:52 AM by lamarn »
roy_043
  • BricsCAD 18
« Reply #28 on: January 17, 2017, 01:41:36 PM »
I have updated the code. See here.
A keyboard shortcut (e.g. F3) can be created for the new c:Osnap-FormToggle function.
lamarn
« Reply #29 on: January 17, 2017, 04:23:17 PM »
Super, thank Roy!!  :yay!:
Sorry for asking but how could c:Osnap-FormToggle than best be added to F3, ..knowing OpenDCL is running
acad says F3 does this
^P'_.osmode $M=$(if,$(and,$(getvar,osmode),16384),$(-,$(getvar,osmode),16384),$(+,$(getvar,osmode),16384))
tried these two mods but it doesn't work out.. :
^P'_.osmode $M=$(if,$(and,$(getvar,osmode),16384),$(-,$(getvar,osmode),16384),$(+,$(getvar,osmode),16384)),c:Osnap-FormToggle
^P'Osnap-FormToggle;_.osmode $M=$(if,$(and,$(getvar,osmode),16384),$(-,$(getvar,osmode),16384),$(+,$(getvar,osmode),16384))
