Author Topic: MAPTRIM via lisp?  (Read 4424 times)
CHulse
MAPTRIM via lisp?
« on: October 30, 2015, 02:43:08 PM »
Does anyone know if it's possible to access the MAPTRIM command (in MAP or C3D) via lisp?
As far as I know, you can't run it via command line...
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
squirreldip
Re: MAPTRIM via lisp?
« Reply #1 on: October 30, 2015, 04:54:15 PM »
Will C:EXTRIM work for you (from Express Tools)?
« Reply #2 on: October 30, 2015, 04:56:53 PM »
due to the dialog interface, probably not
topograph
  • Mosquito
« Reply #3 on: October 31, 2015, 05:38:35 AM »
(command "maptrim" "d" point1 point2 point3 point4 "" "n" "n" "o" "y" "y" "i" "y")
where
  "d" -> Enter trim boundary method (Query/Select/Define):d
    point1 point2 point3 point4  ->coordinates of polygon you want cutting
  "" -> no more points
  "n" ->Filter objects to trim by layer? (Yes/No) <N>: n
  "n" ->Select objects to trim manually? (Yes/No) <Y>: n
  "o" ->Enter trim method (Inside/Outside) <I>: o
  "y" ->Skip topology objects? (Yes/No) <Y>: y
  "y" ->Retain object data? (Yes/No) <Y>: y
  "i" ->Enter non edge object handling method (Delete/Reference/Ignore) <I>:i
  "y"->Objects outside the trim boundary not on frozen or locked layers will be trimmed or deleted.  Proceed? (Yes/No) <Y>:
Arguments is different when you cutting Outside or Inside polygon, be careful.
PS.
Set system variable CMDDIA to 0 and then call command MAPTRIM from command line, you will see :)
CHulse
« Reply #4 on: November 02, 2015, 08:26:07 AM »
Awesome, thank you.
It never occurred to me to try turning CMDDIA off.
Cary Hulse
CHulse
« Reply #5 on: November 02, 2015, 10:16:55 AM »
I considered that. It seemed to run much slower and wasn’t as clean. MAPTRIM allows me to use the last query boundary and that fits my specific workflow perfectly.
Thx
Cary Hulse
