Author Topic: Modify FixBlock to use crossing  (Read 2002 times)
TJAM51
« on: May 05, 2005, 08:29:09 AM »
The following routine only allows for an individual selection of a block (single pick). How could this routine be changed to allow for window or crossing?
;   File Name: FIXBLOCK.LSP
;   Description: Puts all of a blocks sub-entities on layer 0 with color
;   linetype set to BYBLOCK. The block, itself, will remain on
;   its' original layer.
(defun d_FixBlock (/ eBlockSel       ; Block selection
         lInsertData      ; Entity data
         sBlockName      ; Block name
         lBlockData      ; Entity data
         eSubEntity      ; Sub-entity name
         lSubData      ; Sub-entity data
         iCount      ; Counter
  ;; Redefine error handler
  (setq
    d_#error *error*
    *error*  d_FB_Error
  ) ;_ end setq
  ;; Set up environment
  (setq #SYSVARS (#SaveSysVars (list "cmdecho")))
  (setvar "cmdecho" 0)
  (command "._undo" "_group")
  ;; Get block from user and make sure it's an INSERT type
  (if (setq eBlockSel (entsel "\nSelect block to change :"))
      (if (setq lInsertData (entget (car eBlockSel)))
   (if (= (cdr (assoc 0 lInsertData)) "INSERT")
     (setq sBlockName (cdr (assoc 2 lInsertData)))
       (alert "Entity selected is not a block!")
       (exit)
     ) ;_ end progn
   ) ;_ end if
     (alert "Invalid Block Selection!")
     (exit)
   ) ;_ end progn
      ) ;_ end if
      ;; Get block info from the block table
      (setq
   lBlockData (tblsearch "BLOCK" sBlockName)
   eSubEntity (cdr (assoc -2 lBlockData))
      ) ;_ end setq
      ;; Make sure block is not an Xref
      (if (not (assoc 1 lBlockData))
     (princ "\nProcessing block: ")
     (princ sBlockName)
     (princ "\nUpdating blocks sub-entities. . .")
     ;; Parse through all of the blocks sub-entities
     (while eSubEntity
       (princ " .")
       (setq lSubData (entget eSubEntity))
       ;; Update layer property
       (if   (assoc 8 lSubData)
      (setq lSubData
             (subst
          (cons 8 "0")
          (assoc 8 lSubData)
          lSubData
             ) ;_ end subst
      ) ;_ end setq
      (entmod lSubData)
         ) ;_ end progn
       ) ;_ end if
       ;; Update the linetype property
       (if   (assoc 6 lSubData)
      (setq lSubData
             (subst
          (cons 6 "BYBLOCK")
          (assoc 6 lSubData)
          lSubData
             ) ;_ end subst
      ) ;_ end setq
      (entmod lSubData)
         ) ;_ end progn
         (entmod (append lSubData (list (cons 6 "BYBLOCK"))))
       ) ;_ end if
       ;; Update the color property
       (if   (assoc 62 lSubData)
      (setq lSubData
             (subst
          (cons 62 0)
          (assoc 62 lSubData)
          lSubData
             ) ;_ end subst
      ) ;_ end setq
      (entmod lSubData)
         ) ;_ end progn
         (entmod (append lSubData (list (cons 62 0))))
       ) ;_ end if
       (setq eSubEntity (entnext eSubEntity))
               ; get next sub entity
     )            ; end while
     ;; Update attributes
     (idc_FB_UpdAttribs)
   )            ; end progn
   (alert "XREF selected. Not updated!")
      )               ; end if
    )               ; end progn
    (alert "Nothing selected.")
  )               ; end if
;;; Pop error stack and reset environment
  (idc_RestoreSysVars)
  (princ "\nDone!")
  (setq *error* d_#error)
); end defun
; Function to update block attributes
(defun idc_FB_UpdAttribs ()
  ;; Update any attribute definitions
  (setq iCount 0)
  (princ "\nUpdating attributes. . .")
  (if (setq ssInserts (ssget "x"
              (list (cons 0 "INSERT")
               (cons 66 1)
               (cons 2 sBlockName)
              ) ;_ end list
            ) ;_ end ssget
      ) ;_ end setq
    (repeat (sslength ssInserts)
      (setq eBlockName (ssname ssInserts iCount))
      (if (setq eSubEntity (entnext eBlockName))
   (setq
     eSubType (cdr (assoc 0 lSubData))
   ) ;_ end setq
      ) ;_ end if
      (while (or (= eSubType "ATTRIB") (= eSubType "SEQEND"))
       (setq lSubData
         (subst
           (cons 8 "0")
           (assoc 8 lSubData)
           lSubData
         ) ;_ end subst
       ) ;_ end setq
       (entmod lSubData)
     ) ;_ end progn
   ) ;_ end if
       (setq lSubData
         (subst
           (cons 6 "BYBLOCK")
           (assoc 6 lSubData)
           lSubData
         ) ;_ end subst
       ) ;_ end setq
       (entmod lSubData)
     ) ;_ end progn
   ) ;_ end if
       (setq lSubData
         (subst
           (cons 62 0)
           (assoc 62 lSubData)
           lSubData
         ) ;_ end subst
       ) ;_ end setq
       (entmod lSubData)
     ) ;_ end progn
   ) ;_ end if
   (if (setq eSubEntity (entnext eSubEntity))
     (setq
     ) ;_ end setq
     (setq eSubType nil)
   ) ;_ end if
      )               ; end while
      (setq iCount (1+ iCount))
    )               ; end repeat
  )               ; end if
  (command "regen")
)               ; end defun
; Function to save a list of system variables
(defun #SaveSysVars (lVarList / sSystemVar)
  (mapcar
    '(lambda (sSystemVar)
       (setq lSystemVars
         (append lSystemVars
            (list (list sSystemVar (getvar sSystemVar)))
         ) ;_ end append
       ) ;_ end setq
     ) ;_ end lambda
    lVarList
  ) ;_ end mapcar
  lSystemVars
) ;_ end defun
; Function to restore a list of system variables
(defun idc_RestoreSysVars ()
  (mapcar
       (setvar (car sSystemVar) (cadr sSystemVar))
     ) ;_ end lambda
    #SYSVARS
  ) ;_ end mapcar
) ;_ end defun
; Error Handler
(defun d_FB_Error (msg)
  (princ "\nError occurred in the Fix Block routine...")
  (princ "\nError: ")
  (princ msg)
  (if *error*
    (*error* msg)
  ) ;_ end if
  (command)
  (if (/= msg "quit / exit abort")
      (command "._undo" "_end")
      (command "._u")
    ) ;_ end progn
  ) ;_ end if
) ;_ end defun
(defun c:FB () (d_FixBlock))
;;;(fb)
M-dub
« Reply #1 on: May 05, 2005, 08:42:45 AM »
Edited it for you...
<hint = [ code ] [ /code ]>
*But didn't address your initial problem*
« Reply #2 on: May 05, 2005, 09:27:40 AM »
