Author Topic: Can't find 50 Blocks  (Read 5384 times)
craigr
« on: October 29, 2015, 10:44:24 AM »
Attached is a Camera Block that when inserted into a 'clean' CAD File, then run the Purge command with 'list' window open, it purges FIFTY Blocks!!  If I open the block itself, the 50 aren't there.
Now when I try to identify those blocks, without purging, I can't find them.
Do you have any idea what is happening?
Re: Can't find 50 Blocks
« Reply #1 on: October 29, 2015, 10:50:30 AM »
too many anonymous blocks...you will need to rename them to purge them
craigr
« Reply #2 on: October 29, 2015, 10:52:46 AM »
What the %&^$# are these darn things!?  How can I get rid of them if I can't purge them?
I have been pecking away at these for over an hour. I even made new blocks.
« Reply #3 on: October 29, 2015, 11:01:59 AM »
they most often come from users who enjoy the use of copyyclip/pasteclip without understanding what it's real impact on their drawing files actually is...
Bunch of anonymous blocks...
Irony being, autocad hates then yet it allows them to be created...  you RENAME them  block rename *51 to crap01  etc then they can be purged
craigr
« Reply #4 on: October 29, 2015, 11:04:08 AM »
Rename FORTYNINE Times!!!!  -  And I have TWO Blocks that are like this!!
Thanks for the replies though.   :)
ChrisCarlson
« Reply #5 on: October 29, 2015, 11:04:38 AM »
I just opened it up and do not see any anon blocks within 2016's purge window.
Rob...
« Reply #6 on: October 29, 2015, 11:06:00 AM »
I think the use of wild cards will help you renaming.
CAD Tech
« Reply #7 on: October 29, 2015, 11:14:35 AM »
other option recreate the stupid camera block...it is nothing special
craigr
« Reply #8 on: October 29, 2015, 11:15:25 AM »
My 2013LT won't let me rename those blocks.
I tried both the 'Rename' and '-Rename' commands with no success.
craigr
« Reply #9 on: October 29, 2015, 11:18:00 AM »
I did remake this simple block a couple of times, copycliping out of the Block editor into a new dwg and all of the garbage came with it, so I will have to make it from scratch.
I know I could remake it pretty easily, by posting this, I was hoping to learn what the garbage is, why it is there so I don't do it again and lastly, how to get rid of it.
Thanks for the replies folks.
« Reply #10 on: October 29, 2015, 11:22:23 AM »
The garbage is strong with this one...
I even did a single wblock...and still 2(two) of the anoying anonymous blocks came along for the ride.
« Reply #11 on: October 29, 2015, 03:24:04 PM »
No anonymous blocks here after a cleaning.
craigr
« Reply #12 on: October 29, 2015, 03:26:05 PM »
Sweet! - How did you clean it?
One more?
« Reply #13 on: October 29, 2015, 03:28:22 PM »
Wblock the drawing over itself.
craigr
« Reply #14 on: October 29, 2015, 03:29:23 PM »
Will do. - Thanks
