I've been using this for a while now. When you have new layers that you want to freeze, run this routine, select a vport with the "bad" layers,then pick the objects on that layer....bingo! frozen in all vports. Not *totally* automatic, but close.......
;Will freeze selected layers in ALL vports, you pick 'em, they're chilled!
;Thanks to the "gurus" at CADalog forums for this routine...3/7/03
;Keith, Trev, Hendie & Paul
(defun c:vplfrz ()
(setvar "TileMode" 0) ; Force PaperSpace
(setq vpFlag (getvar "cvport"))
(if (= vpFlag 1)
(setq sel-vpt 1)
(setq sel-vport (car (entsel "\nSelect view port: ")))
(if (= sel-vport nil)
(alert "You must select a viewport\nTry again!")
(c:vplfrz)
(setq entvport (entget sel-vport))
(if (= (cdr (assoc 0 entvport)) "VIEWPORT")
(frz-vplayer)
(c:vplfrz)
); else Viewport is already selected
(frz-vplayer)
) ;endif (= vpFlag 1)
(defun frz-vplayer ()
(setq e2 (entget sel-vport)
viewport (cdr (assoc 69 e2))
(command "mspace")
(setvar "cvport" viewport)
(setq loop "")
(while loop
(setq
pik (nentsel "\nSelect an item on XREF to Freeze: ESC to Exit:")
((/= pik nil)
(setq lay (assoc 8 (entget (car pik))))
(setq str (cdr lay))
(command "vplayer" "f" str "All" "") ; Freeze in ALL viewports
((= pik nil)
(alert "Nothing Selected!\nTry Again!")
(frz-vplayer)
) ; End while
(command "pspace")
(prompt "\nType VPLFRZ to run")
(prin1)
Don't know how helpful it'll be, but maybe it can be "tweaked" to do what it doesn't, if it doesn't do what you want/need.......
