Hi everyone,
I have to do work for a client who uses AutoCAD Architecture.
The work is quite simple: count the blocks in the drawing.
For objects INSERT I have no problem, as identification code can use the name of the block.
But in these drawings I must also count "AEC_MVBLOCK_REF" and "AEC_WALL"
With the following code I see all the characteristics of these objects:
(defun c:propogg (/ obj vlaobj)
(setq obj (car (entsel)))
(setq vlaobj (vlax-ename->vla-object obj))
(vlax-dump-object vlaobj T)
However I can see them only with AutoCAD Architecture, while with AutoCAD Full / BricsCAD I can see only the generic characteristics.
There is some way to get more information (eg, stylename for objects AEC_MVBLOCK_REF, using AutoCAD Full (no Architecture) and/or BricsCAD?
