Author Topic: No Plot line on Plotting layer  (Read 5908 times)
Pukenzz
Re: No Plot line on Plotting layer
« Reply #15 on: October 27, 2015, 08:42:02 PM »
OK all thanks for the great input.  Still set in my ways.  Maybe this next question should push to a new thread but...
All line weights plot as I would assume but .0000 lineweights shows up.  I would think it would no. Greater the number thicker the line.  Lesser the number thinner the line.    Am I missing something?
cadtag
« Reply #16 on: October 28, 2015, 08:04:51 AM »
My understanding is that a lineweight of 0 is interpreted as 'the thinnest line the device can create'.  So a 180DPI printer will print a line of weight 0.000000 that is 'fatter' than a 1200DPI device would.
If you don't want it on the paper, but do want to see it on screen, use a no-plot layer for that linework.
« Reply #17 on: October 28, 2015, 09:48:57 AM »
Since you're not going to use layers then put the objects you don't want to plot to RGB 255 255 255.
cadtag
« Reply #18 on: October 28, 2015, 10:23:55 AM »
good idea.  just watch out for draworder, otherwise you may end up with white lines crossing on top of black lines, and leaving an unexpected gap on the paper.
ChrisCarlson
« Reply #19 on: October 28, 2015, 03:21:07 PM »
This will only work provided the plot style is set to interpret 255 as plot white, not plot black or shade of grey.
Rob...
« Reply #20 on: October 28, 2015, 03:30:03 PM »
RGB colors by-pass the plot settings.
CAD Tech
« Reply #21 on: October 28, 2015, 04:49:05 PM »
What Rob.. said :)
