Just wanted to say I have been reading this website for quite a while haven't posted much. I am one of the rare few who hasn't made the switch to C#. I have pused VB.net much further than most. The amount of tutorials start getting limited when you get more advanced with VB.net.
I was reading Keans webpage through the interface about using SyncContext for dealing with multithreading in AutoCad
http://through-the-interface.typepad.com/through_the_interface/2013/01/integrating-leap-motion-and-autocad-basic-navigation.html. I think I have the concept down. Created a dummy form in Autocad on the main thread then initialialize it, set your synccontext to current. Spin up a thread, used the synccontext.post to send it back to the main thread.
Below I can make it work with a VB.net windows form class.Imports System.IO
Imports System.Threading
Public Class Form1
Private m_SyncContext As System.Threading.SynchronizationContext
Private m_DestinationPath As String
Private thread As Thread
Public Sub New()
' This call is required by the designer.
InitializeComponent()
' Add any initialization after the InitializeComponent() call.
Me.m_SyncContext = System.Threading.SynchronizationContext.Current
End Sub
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Dim id As Integer = thread.CurrentThread.ManagedThreadId
thread = New Thread(AddressOf searchDwgs)
thread.Start()
End Sub
Private Sub searchDwgs()
' searching through an opening drawings on the thread pool
Me.m_SyncContext.Post(AddressOf UpdateTextBox, "[New Text]")
End Sub
Private Sub UpdateTextBox(param As Object)
If (TypeOf (param) Is String) Then
Me.TextBox3.AppendText(CStr(param))
End If
End Sub
End Class
Now I have trouble making it work if I try an make it work just from the console, and put in a dummy form to get it going like Keans example.Imports System.IO
Imports System.Windows.Forms
Module Module1
Dim m_frmDummy As Form
Dim m_SyncContext As System.Threading.SynchronizationContext
Dim id As Integer
Dim thread As Thread
Sub Main()
m_frmDummy = New Form
m_frmDummy.InitializeLifetimeService()
id = thread.CurrentThread.ManagedThreadId
thread.Start()
End Sub
End Sub
MsgBox(CStr(param))
End If
End Sub
End Module
