Author Topic: MTEXT set to OLDEDITOR issue...  (Read 1827 times)
Andrea
« on: October 16, 2015, 11:12:02 AM »
Hi all,.
I've note this ...
If you are creating MTEXT entities with INTERNAL editor..
then, switch the MTEXTED to OLDEDITOR.
you will not be able to edit the MTEXT entity because it was created with the INTERNAL editor.
so if you create new MTEXT entity while you are using OLDEDITOR...you will be able to edit without problem.
see animated GIF.
Keep smile...
rkmcswain
Re: MTEXT set to OLDEDITOR issue...
« Reply #1 on: May 05, 2016, 12:19:11 PM »
Change MTEXTED to Notepad.
It will edit anything.
MSTG007
« Reply #2 on: May 05, 2016, 01:16:04 PM »
wow, never knew about this.... cool.
Civil3D 2020
