AutoCAD Express Tools to be installed. On the Express Tools tab of the Ribbon, expand the Tools panel to find the Make Linetype and Make Shape buttons.
*FOO,FOO_ _ _ _ _A,1.0,-6.0
The distance is dependent on your ltscale setting. If it's set to 1, then the following simple linetype should work:Quote*FOO,FOO_ _ _ _ _A,1.0,-6.0
Quote from: ronjonp on October 14, 2015, 01:55:18 PMThe distance is dependent on your ltscale setting. If it's set to 1, then the following simple linetype should work:Quote*FOO,FOO_ _ _ _ _A,1.0,-6.0Thank you Ron,But I have to change the linetype scale to 10.0 to work fine!How Can I set the scale from the file?
Quote from: FABRICIO28 on October 14, 2015, 02:02:39 PMQuote from: ronjonp on October 14, 2015, 01:55:18 PMThe distance is dependent on your ltscale setting. If it's set to 1, then the following simple linetype should work:Quote*FOO,FOO_ _ _ _ _A,1.0,-6.0Thank you Ron,But I have to change the linetype scale to 10.0 to work fine!How Can I set the scale from the file?Your drawing has an ltscale of 0.1 so multiple the -6.0 * 10 & an object ltcale of 1 should work.
or look into CELTSCALE
one could also set the layer that uses this linetype to the desired scale and leave CELTSCALE alone...
within Civil3d Object styles one can set ltscale by layer
