Author Topic: Create a linetype  (Read 4316 times)
Fabricio28
Create a linetype
« on: October 14, 2015, 11:27:51 AM »
Hi guys,
I'm trying to create a custom linetype. But I don't know how to do that.
I'm attaching a dwg example.
Thank in advance
Rob...
Re: Create a linetype
« Reply #1 on: October 14, 2015, 11:32:22 AM »
There is a nice linetype generator around here somewhere.
CAD Tech
« Reply #2 on: October 14, 2015, 11:45:54 AM »
-----------   Line Type Loader /  Maker  ----------------
http://www.theswamp.org/index.php?topic=23888.0  LineType Loader by CAB - function to load a list of linetypes
http://www.theswamp.org/index.php?topic=31115.0 Advanced Linetype Loader  by Lee Mac
http://www.theswamp.org/index.php?topic=21339.msg258481#msg258481  LineType maker by RonJ
« Reply #3 on: October 14, 2015, 11:47:58 AM »
AutoCAD Express Tools to be installed. On the Express Tools tab of the Ribbon, expand the Tools panel to find the Make Linetype and Make Shape buttons.
Fabricio28
« Reply #4 on: October 14, 2015, 12:35:53 PM »
Guys,
Thank very much for replay.
It's good.  :-D
But I'd like make  something more specific. Start and End point with 1.0 and Gap with 6.0. Is it possible?
Just like the example.
Regards
« Reply #5 on: October 14, 2015, 01:55:18 PM »
The distance is dependent on your ltscale setting. If it's set to 1, then the following simple linetype should work:
*FOO,FOO_    _    _    _    _
A,1.0,-6.0
Fabricio28
« Reply #6 on: October 14, 2015, 02:02:39 PM »
*FOO,FOO_    _    _    _    _
A,1.0,-6.0
Thank you Ron,
But I have to change the linetype scale to 10.0 to work fine!
How Can I set the scale from the file?
« Reply #7 on: October 14, 2015, 02:14:27 PM »
*FOO,FOO_    _    _    _    _
A,1.0,-6.0
Thank you Ron,
Your drawing has an ltscale of 0.1 so multiple the -6.0 * 10 & an object ltcale of 1 should work.
« Reply #8 on: October 14, 2015, 02:16:01 PM »
or look into CELTSCALE
Fabricio28
« Reply #9 on: October 14, 2015, 02:17:51 PM »
*FOO,FOO_    _    _    _    _
A,1.0,-6.0
Thank you Ron,
Thank Ron!!
Perfect my friend :)
Fabricio28
« Reply #10 on: October 14, 2015, 02:18:42 PM »
Hi mjfarrell
I've changed CELTSCALE to 10.0.  :-D
Thank you
« Reply #11 on: October 14, 2015, 04:04:10 PM »
one could also set the layer that uses this linetype to the desired scale and leave CELTSCALE alone...
CHulse
« Reply #12 on: October 15, 2015, 11:55:56 AM »
Am I reading this right? Is it possible to set LTSCALE by layer? If so, I didn’t know that was possible.
Or do you just mean select all the objects on the layer and change their linetype scale?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
« Reply #13 on: October 15, 2015, 12:04:27 PM »
within Civil3d Object styles one can set ltscale by layer
CHulse
« Reply #14 on: October 15, 2015, 02:06:07 PM »
Thanks. I'll look for that.
Cary Hulse
