Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Dialog woes
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Dialog woes (Read 1623 times)
CincyJeff
Newt
Dialog woes
on:
October 13, 2015, 10:27:49 AM »
I'm trying to create a routine that will scan the drawing for blocks on a certain layer that have visibility states. It will then display the name of each block with the current visibility state in a pop-up list. The user will then be able to change the visibility state for each block using the available options in each pop-up list. Since I don't know how many blocks there may be I create the dialog on the fly. I've taken the basic code shown below from Lee Mac's MASK routine. Thanks Lee. The temporary dialog file is created and loads fine. It also allows me to change the pop-up list for each block. However, I cannot get the value of each pop-up list on close. I've even stopped the program before the dialog is unloaded and before the temporary file is deleted and I still cannot use get_tile to retrieve the pop-up list values. If the dialog closes with OK, dlgval will be 1 so the if statement in the code will run to create symbols line1, line2, etc... for each block. The symbol arglst is a list of visibility states for each block, e.g. ((vis1 vis2) (vis1 vis2 vis3) ...). The commented out action_tile code also does not work. Any ideas?
Code - Auto/Visual Lisp:
[Select]
defun
DSET:RUNDIALOG
cntr dlgid dlgval file filename
cond
null
and
setq
filename
vl-filename-mktemp
nil
nil
".dcl"
setq
file
open
filename
"w"
progn
foreach
line
append
"MainDetailSet : dialog {"
"label =
Detail Set
DSET:DLGLINES
"ok_cancel;"
;_ end of append
write-line
line file
;_ end of foreach
setq
file
close
file
0
setq
dlgid
load_dialog
filename
;_ end of progn
;_ end of and
;_ end of null
princ
\n
Unable to Load Dialog."
t
while
not
member
dlgval '
0
1
cond
null
new_dialog
"MainDetailSet"
dlgid
princ
\n
Cannot find Detail Set Dialog Definition."
setq
dlgval
0
t
setq
cntr
1
foreach
item arglst
set
read
strcat
"t:lst"
itoa
cntr
nth
1-
cntr
arglst
;_ end of set
start_list
strcat
"t:line"
itoa
cntr
3
mapcar
add_list
vl-symbol-value
read
strcat
"t:lst"
itoa
cntr
;_ end of mapcar
end_list
set_tile
strcat
"t:line"
itoa
cntr
car
nth
1-
cntr
arglst
;_ end of set_tile
;;; (action_tile
;;; (strcat "t:line" (itoa cntr))
;;; "(set (read (strcat \"line\" (itoa cntr)))
;;; (get_tile (strcat \"t:line\" (itoa cntr)))
;;; )" ;_ end of set
;;; ) ;_ end of action_tile
setq
cntr
1+
cntr
;_ end of foreach
setq
dlgval
start_dialog
;_ end of cond
;_ end of while
;_ end of cond
if
1
dlgval
progn
setq
cntr
1
while
cntr
length
arglst
set
read
strcat
"line"
itoa
cntr
get_tile
strcat
"t:line"
itoa
cntr
;_ end of set
setq
cntr
1+
cntr
;_ end of while
setq
dlgid
unload_dialog
dlgid
;_ end of progn
;_ end of if
if
0
dlgid
setq
dlgid
unload_dialog
dlgid
;_ end of if
if
and
filename
findfile
filename
vl-file-delete
filename
;_ end of if
UTIL:RESETDEBUG
;_ end of defun - DSET:RUNDIALOG
defun
DSET:DLGLINES
cntr dlgline
setq
cntr
1
foreach
item blklst
setq
dlgline
append
dlgline
list
": row {"
": text {"
strcat
"label =
car
item
"fixed_width = true;"
"width = 50;"
": popup_list {"
strcat
"key =
t:line"
itoa
cntr
"width = 50;"
;_ end of list
;_ end of append
;_ end of setq
setq
arglst
append
arglst
cddr
item
setq
cntr
1+
cntr
;_ end of foreach
dlgline
;_ end of defun - DSET:DLGLINES
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: Dialog woes
Reply #1 on:
October 13, 2015, 12:36:11 PM »
You are trying to read values from a dialog that is already closed.
Create an action for the "accept" button that reads and stores the values. I would store them in a list instead of creating lots of unlocalised variable names on the fly.
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: Dialog woes
Reply #2 on:
October 13, 2015, 12:53:32 PM »
The code you have commented out should be (untested):
[Select]
action_tile
strcat
"t:line"
itoa
cntr
strcat
"(setq line"
itoa
cntr
" (get_tile
t:line"
itoa
cntr
Logged
CincyJeff
Newt
Re: Dialog woes
Reply #3 on:
October 13, 2015, 01:46:35 PM »
Thanks roy_043, the action_tile code did the trick. I'll look into the list idea as it does make more sense. Thanks again.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
Dialog woes
