As far as I am aware, you cannot nest field expressions within a DIESEL expression, therefore, unless you assign the values of the linear parameters to user system variables, you will be unable to reference these values from within a DIESEL expression.
An alternative approach would be to use Formula Field (AcExpr), however, these do not support conditionals and there are no min/max formula functions.
