CAD Forums > CAD General
Acad 2014 doesn't find LTYPESHP.SHX
tedg:
--- Quote from: ronjonp on September 15, 2015, 11:49:24 AM ---Maybe post a sample drawing?
--- End quote ---
I had a coworker send me his acad.lin and ltypeshp.shx files and I placed them in the support folder and am getting the same issue.
Attached is a drawing and some screen shots. you'll see the fenceline1 is a dashed line without the circles for me anyway.
mjfarrell:
PROBLEM IS....
LTYPESHP.shx is a shape file, not a text font file.
ronjonp:
That file works fine for me...
tedg:
--- Quote from: ronjonp on September 15, 2015, 12:29:23 PM ---That file works fine for me...
--- End quote ---
Ok thanks.
I tried the same files and paths that others use without an issue for them...
I made sure the support path is there,
What else in an Acad set up be causing this?
I also made sure there were no "copies" of these files anywhere else in my support paths
cadtag:
Just for grins, can you load and use the SHAPEs via the LOAD command for the shx, and the SHAPE command to place a named shape from it?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
