Author Topic: Get list of string from string?  (Read 2452 times)
TimSpangler
  • CAD Naked!!
« on: May 03, 2005, 08:25:50 AM »
I have created the following code that does what I want it to do but, can it be done better or faster?
;; Create filters from layer names
;; Sub to create a lists from a delimited string i.e.  "a-anno-test" = ("a"  "anno" "test")
(defun CREATE_FILTERS (String Delim / StringCount Counter ChurChar Sting1)
(setq Sting1 "")
(setq List1 '())
(setq StringCount (1+ (strlen String)))
(setq Counter 1)
(repeat StringCount
(setq ChurChar(substr String Counter 1))
(if (or(= ChurChar "")(= ChurChar Delim))
(setq List1 (cons Sting1 List1))
(setq Sting1 "")
(setq Sting1 (strcat ChurChar Sting1))
(setq Counter (1+ Counter))
(setq List1 (reverse(mapcar  '(lambda (x)(REV_STRING x))List1)))
(defun REV_STRING (String / ChurChar Counter NewString StringCount)
(setq NewString "")
(setq StringCount (strlen String))
(setq Counter 1)
(repeat StringCount
(setq ChurChar (substr String Counter 1))
(setq NewString (strcat ChurChar NewString))
NewString
Anyone willing to give it a go?
Edited:
I am also looking at changing the code to look for certian delimeters, then create the list of string based on certian delimeters.
Q:
What would you consider delimeters?
ACA 2015 - Windows 7 Pro
David Bethel
« Reply #1 on: May 03, 2005, 08:32:25 AM »
Here's an old one that creates a list from a string and allows for STR or NUMBERP atoms.  -David
;|;SUB -> CONVERT DELIMITED STRING TO LIST (NUMERIC or STRING ATOMS)
;;;ARG -> Single Delimiter Character
          String To Convert
          Flag T=Numeric nil=String
;;;RET -> List or nil
;;;Error checking -> NONE what so ever  |;
(defun ds2l (d s f / sl f sv dlist slist)
  (setq sl (strlen s)
         f 0)
  (setq dlist (list 0))
  (while (<= (setq f (1+ f)) sl)
         (if (= d (substr s f 1))
             (setq dlist (cons f dlist))))
  (setq dlist (cons (1+ sl) dlist))
  (setq dlist (reverse dlist))
  (repeat (1- (length dlist))
          (setq sv (substr s (1+ (nth 0 dlist))
                             (- (nth 1 dlist) (nth 0 dlist) 1)))
          (if f
            (setq slist (cons (atof sv) slist))
            (setq slist (cons sv slist)))
          (setq dlist (cdr dlist)))
  (reverse slist))
R12 Dos - A2K
« Reply #3 on: May 03, 2005, 11:41:45 AM »
Quick thinking outside the box ...
(defun ToList ( string delim / value convert main )
    ;;  delim is a one character string like
    ;;  a comma "," or a pipe "|" etc.
    (defun value ( x / result )
        (vl-catch-all-apply
           '(lambda ()
                (vl-some
                   '(lambda (units) (setq result (distof x units)))
                    (list (getvar "lunits") 4 5 2 1)
        (if result
            (if (vl-string-position 46 x)
                result
                (fix result)
    (defun convert ( lst / string )
            (   (value
                    (setq string
                        (vl-list->string lst)
            (   string   )
    (defun main ( string delim / item lst )
        (setq delim (ascii delim))
        (foreach code (reverse (vl-string->list string))
                (   (eq delim code)
                    (if item
                        (setq
                            lst  (cons (convert item) lst)
                            item nil
                (   (setq item
                        (cons code item)
        (if item
            lst
    (main string delim)
(ToList "abc,123,def,456.7" ",") => ("abc" 123 "def" 456.7)
