Author Topic: Possible to convert Volume Surface to Tin Surface?  (Read 3753 times)
nobody
  • .net stuff
« on: August 11, 2015, 12:50:22 AM »
Is there a simple way to convert a volume surface to a tin surface?
cadtag
Re: Possible to convert Volume Surface to Tin Surface?
« Reply #1 on: August 11, 2015, 07:49:19 AM »
export to landxml, and then import?
« Reply #2 on: August 11, 2015, 08:22:48 AM »
Why would one need to?
But yes, export LandXML  and import to surface collection.
nobody
  • .net stuff
« Reply #3 on: August 11, 2015, 05:09:57 PM »
Thanks cadtag/MJ...nothing really c3d or design related... I can't seem to find a way to access volume surface data using .net so I need to get it in tin or grid form.
« Reply #4 on: August 11, 2015, 05:14:00 PM »
What volume surface 'data' are you after?
nobody
  • .net stuff
« Reply #5 on: August 18, 2015, 01:33:34 AM »
Hey MJ... the idea is to present color themed cut / fill quantities, but I'm unable to apply them to volume surfaces through .net; I need the surface to be a tin or grid surface to apply the elevation analysis and the proper colors... at least in the way I know how.
« Last Edit: August 18, 2015, 01:37:59 AM by Alien »
« Reply #6 on: August 18, 2015, 08:54:52 AM »
why would you not use the onboard analysis tools to do this theming? We do it here for different contractors.
What extra function or value does your DOT......Nyet solution give you?
huiz
  • Certified Prof C3D
« Reply #7 on: August 24, 2015, 02:21:03 AM »
Why is it not possible to do this via .Net? I wrote a custom Color Scheme editor and am able to apply the themes to Tin Surfaces as well to Tin Volume Surfaces.
« Reply #8 on: August 24, 2015, 09:52:22 AM »
I guess Alien will want to post his code so that you can help him 'fix' that part that doesn't work with Volume Surfaces.
pekkaesko
  • Mosquito
« Reply #9 on: September 27, 2015, 12:49:22 AM »
In order to get Tin surface from volume surface, you can create a new, empty surface and paste your volume surface into this new surface.
