This ties back to the code on this page here.
http://www.theswamp.org/index.php?topic=49770.msg549346#newI'm trying to understand how to add a circle to a portion of the code above.
When you execute the original code it will draw a parking stall line that is a "T" 20' long.
I would like it to draw a parking stall line "I" and add a circle to the right side that is 2' Radius in the middle of the parking stall.
h2 = 20' (Because it would draw a 9'x20' parking stall).
Right now as it draws it creates a polyline that is a "T".
(command "pline" (list 0 0 0) (list 0 h2 0) (list -0.5 h2 0) (list 0.5 h2 0) "")
I wanted to remove the "T" and just have a line "I" and a circle "o" to one side if possible.
(command "pline" (list 0 0 0) (list 0 h2 0) "circle" (list 4.5 4.5 0) (list "Radius Size") "")
;;------------------------------Create Block-------------------------------
(defun BLKP()
(if (not (tblsearch "block" "PARP"))
(setq osm (getvar "OSMODE"))
(setvar "OSMODE" 0)
; Enter parking bay Block Length
(if (not h2) (setq h2 6.00))
(setq h (getreal (strcat "\nSpecify Parking Bay Height <" (rtos h2 2 2) ">:")))
(if (not h) (setq h h2)(setq h2 h))
(command "CLAYER" "0")
(command "-BLOCK" "PARP" (list 0 0 0) (entlast) "")
(setvar "OSMODE" osm)
) ;progn
) ;if
) ;defun
I hope this makes some sense. Thanks for any help on this!
