Author Topic: Insomnia? Simple, write a typoglycemia function.  (Read 6512 times)
« on: April 29, 2005, 05:07:29 AM »
What?
Remember this nonesence, typoglycemia?
I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg The phaonmneal pweor of the hmuan mnid Aoccdrnig to rscheearch taem at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae. The rset can be a taotl mses and you can sitll raed it wouthit a porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe. Such a cdonition is arppoiately cllaed Typoglycemia :)- Amzanig huh? Yaeh and yuo awlyas thought slpeling was ipmorantt!
Well, when you have insomnia and need something mindless and mildy interesting to keep from going mad you write crud like this --
(defun typos ( text / scramble middle rotate main )
    (defun scramble ( codes )
        (if (< (length codes) 4)
            codes
            (append
                (list (car codes))
                (rotate (middle codes))
                (list (last codes))
    (defun middle ( lst )
        (cdr
            (reverse
                (cdr
                    (reverse lst)
    (defun rotate ( lst )
        (cons
            (last lst)
            (reverse
                (cdr
                    (reverse lst)
    (defun main ( text / punc codes result )
        (setq punc
            (vl-string->list
                "\".?!:-,;/()[]{}\n\r\t "
        (foreach code
            (reverse
                (vl-string->list
                    (vl-string-trim
                        " \t\n"
                        text
                (   (member code punc)
                    (if codes
                        (setq result
                            (cons
                                (scramble codes)
                                result
                            codes nil
                    (setq result
                        (cons
                            (list code)
                            result
                (   (setq codes
                        (cons
                            code
                            codes
        (vl-list->string
            (apply 'append
                (if codes
                    (cons
                        (scramble codes)
                        result
                    result
    (main text)
(typos "Now, whenever you feel the need to ...")
Now, wehenevr you feel the need to aonny yuor fdriens, or jsut slpel lkie Jhon, jsut psas yuor txet tghrouh tihs slimpe rnoutie!
Edit: Distilled routine.
« Reply #1 on: April 29, 2005, 05:15:29 AM »
Insomnia, take a book to bed. I have broken several pairs of glasses doing just that.
coding for typoglycemia :
You raelly firgthen me Michael
:D
Dont let John near that code ...
« Reply #2 on: April 29, 2005, 05:20:13 AM »
Quote from: Kerry Brown
I fhterign melysf dood! :shock:
Good one, it wulod rdeenr his slinpelg erorr fere. :lol:
MickD
« Reply #3 on: April 29, 2005, 05:38:52 AM »
What's Typoglycemia??? :lol:
Seriously though, I had no trouble reading that post, is that a good thing?
- John Carmack
- J.R.R. Tolkien
« Reply #4 on: April 29, 2005, 07:44:46 AM »
Oh my, if you can read that you have a case of it too.
I recommend bourbon, and lot's of it. :)
daron
« Reply #5 on: April 29, 2005, 07:51:23 AM »
That is cool.
David Hall
  • Automatic Duh Generator
« Reply #6 on: April 29, 2005, 09:18:05 AM »
MP - D@MN, thats cool
MickD - Good to see you here
CAB - Whose pouring?
« Reply #7 on: April 29, 2005, 10:10:12 AM »
Burbon (most alcohol) gives me terrible heartburn.
Thanks anyway guys. I think I'll just get a large mallet to put beside the bed; could double for caveman foreplay.
SMadsen
« Reply #8 on: April 29, 2005, 05:33:05 PM »
Now the real task: scramble the code above and write a program that teaches the computer to deal with typoglycemia as well as humans deal with it.
« Reply #9 on: April 29, 2005, 06:04:18 PM »
How about some pseudo code?
First have a dictionary sorted by first letter then by length then by last letter.
The dictionary is made of list grouped as sorted,
Convert the string into words, individual strings using space as the delimiter.
Loop through the list of strings.
If strings less than 4 letters
  add to reconstruct list plus space
Else
  Find the Dictionary list with the match of first char, last char & length match.
  Loop through the dictionary sub list
  Find the match for any word using the interior letters.
Done.
Some words will not be processed correctly but you could restruct your dictionary
to push the high percentage words to the top.
Well never as good as the human computer. But it will give something for Michael to
do the next sleepless night. :)
« Reply #10 on: April 29, 2005, 09:28:37 PM »
Fnuny sftuf gyus, lol.
If one wree to tkae tihs on sleriosuy the way to do it wloud be taht if run tcwie it wloud rretun the oariginl txet, saimilr to a slimpe xnorig eoncryptin smchee.
pmvliet
« Reply #11 on: May 05, 2005, 10:53:49 AM »
In a way reversing this is doable.
Text messaging in a Cell Phone has predictive text.
If there was s text database, the computer can identify the first and last letter, it can figure out how many character's long the word is
and compare that to the database...
How many words start with T, end with T and is 4 character's long...
ok... it's the middle of the day and not night time.  :D
Pieter
« Reply #12 on: May 05, 2005, 12:02:26 PM »
As stated, the easiest thing to imlement is a scheme, analagous to simple xoring bit twiddling, that results in the original string being generated if the routine is run twice.
This variant will do that:
(defun typos ( text / scramble middle group flip main )
            codes
            (append
                (list (car codes))
                (flip (middle codes))
                (list (last codes))
        (cdr
            (reverse
                (cdr
                    (reverse lst)
    (defun group ( lst len / group result )
        (foreach item lst
                (eq len
                    (length
                        (setq group
                            (cons item group)
                (setq
                    result (cons group result)
                    group  nil
        (reverse
            (mapcar 'reverse
                (if group
                    (cons group result)
                    result
    (defun flip ( lst )
        (apply 'append
            (mapcar 'reverse
                (group lst 2)
        (setq punc
            (vl-string->list
        (foreach code
            (reverse
                (vl-string->list
                    (vl-string-trim
                        " \t\n"
                        text
                    (if codes
                        (setq result
                            (cons
                                (scramble codes)
                                result
                            codes nil
                    (setq result
                        (cons
                            (list code)
                            result
                (   (setq codes
                        (cons
                            code
                            codes
        (vl-list->string
            (apply 'append
                (if codes
                    (cons
                        (scramble codes)
                        result
                    result
    (main text)
Example:
(setq JohnSpeak
    (typos
        (strcat
            "Admittedly, I am a hopeless nerd. "
            "I'm ok with that assessment."
=> "Amdtietldy, I am a hpoleses nred. I'm ok wtih taht asssemsnet."
(typos JohnSpeak)
=> "Admittedly, I am a hopeless nerd. I'm ok with that assessment."
:cheesy:
jonesy
  • SuperMod
Re: Insomnia? Simple, write a typoglycemia function.
« Reply #13 on: May 09, 2005, 07:01:26 AM »
Quote from: MP
If this is true how do dyslexic people read?
« Reply #14 on: May 09, 2005, 07:39:38 AM »
?siht ekil ti t'nsi tub ,sklof hcus fo thgil ekam ot hsiw t'nod I
